Mister Horse: Previewer for After Effects
Mister Horse: Previewer - Плагин для Adobe After Effects, который позволяет быстро просматривать файлы, выбранные в панели проектов. Вы можете просмотреть видео, изображения, аудио или первые кадры композиций. Довольно удобно при работе с AEP-шаблонами, например, от VideoHive.
Features:
Preview Video
If you have many clips which you need to combine in Timeline in the right way, you can quickly preview which one is which. No need to open it in the tedious footage viewer. And yeah, that is a kickflip!
Preview Audio
Now you can listen to and preview audio in AE. Sound effects, music, voiceovers.
Preview Images
Is that a boob or it’s a knee? Scale it to better see every pixel. If you have many similar images, it’s way faster to browse if you see a bigger picture. Or a bigger boob.
Preview images with transparency
Many similar PNG’s? Yeeeha, use previewer! You can use transparency grid or choose a custom color.
Preview first frame of Compositions
If you have many precomps or when you are editing some versatile AE project file template, this might be useful. You wouldn’t have to open each comp to see what is there, before you use put it to Timeline.
And Some Fancy Settings…
Change the background for transparent images, scaling method, autoplay or loop playback.
Editing AE Project Files?
Previewer can be very handy when you’re working with project-file templates, like those from VideoHive. There is usually a lot of images or precomps, which you want to preview before you use them.
Compatible:
After Effects CC 2015, CC 2014, CC, CS6, CS5
Release Name: Mister Horse: Previewer
Release Date: July 8, 2015
Homepage
Interface Language: English
Requirements: After Effects CC 2015 - CS5
Размер файла: 17.1Mb
