GenArts Sapphire Plug-ins AE v9.0.2.1 CE for After Effects (Win64)
Sapphire Plug-ins for After Effects - Пакет из более чем 250 плагинов для Adobe After Effects и Premiere Pro. Эти плагины, предназначенные для обработки изображений и синтеза эффектов, разделены на несколько категорий: освещение, стилизация, искажение, наведение резкости, эффекты перехода и т.д. Каждое дополнение имеет набор параметров, которые можно анимировать, благодаря чему количество эффектов, которые можно получить с помощью плагинов, увеличивается во много раз.
Benefits:
- Endless creative possibilities
- The quantity of visual effects allows for countless effect-blending options
- Ease and speed of use is a cost-effective time-saver
- More time available for creativity and high-quality end results
- Blazing fast performance maximizes productivity
- Remarkably organic and natural-looking photoreal results
- Quickly and easily iterate on effect looks
- Visual control of look creation
- Quick reference for all effect parameters
- Convenience of multiple platform options
- Highly reliable engine
Features:
- Over 250 visual effects
- Resolution-independent
- GPU-accelerated for Nvidia CUDA cards
- Multiprocessor support
- 32-bit float support
- Intuitive user interface
- On-screen UI widgets for many video effects
- Offline HTML and PDF documentation included
- Create unique natural and organic lighting using rays, lens flare, zap, glare, glint, and glow effects
- Create backgrounds and organic displacement maps using a large selection of texture generators
- Choose from a wide variety of fast-processing color channel, directional, and defocus blurs
- Stylize and color-correct your footage with a selection of effects including FilmEffect, HalfTone, Vignette, BleachBypass, and Cartoon
- Free unlimited render licenses
- Same license works on Adobe Premiere Pro, and also Apple Final Cut Pro (if used on the same machine)
New Features - Builder with Enhanced Preset Browser:
Builder gives users the ability to create their own effects and transitions in a node-based workspace for unprecedented creativity and efficiency, thus unleashing the full power of Sapphire. In Builder, users have the flexibility to stack and connect Sapphire effects in ways that were not previously possible in Adobe and Avid hosts. All new effects and transitions developed in the workspace are saved as cross-host presets, and are loaded as a single plugin onto a timeline. This flexibility can be especially helpful for editors. Since Builder allows effects to be combined, results that would have taken multiple steps can now be achieved with a single effect.
New in Sapphire Plug-ins v9:
Key Effects and Updates:
- BokehLights: Generates beautifully complex and creative patterns of defocused lights that animate and scale over time.
- NightSky: Astronomically accurate star field renderer. Specify date, time, and location to generate correct nighttime skies.
- Aurora: Produces swirling patterns similar to the Aurora Borealis. Many different modern, subtle, and abstract looks can be easily achieved.
- InfiniteZoom: Creates a hypnotic, spiral effect similar to infinite regression.
- CutToDissolve (transition): Replaces a straight cut with a dissolve seamlessly by generating missing frames using optical flow technology.
- RepairFrames: Fixes any damage (bad pixels, dropouts, random noise) in a frame automatically.
- Builder Improvements: Multiple transition nodes and animation curves enable more power and freedom for building cutting edge custom effects.
https://www.youtube.com/watch?v=jWuKyhI_OJ4
Compatibility matrix:
OS: Windows 7, 8, 10 (64-bit)
Host Platform:
- Adobe After Effects CS6, CC, CC 2014, CC 2015
- Adobe Premiere Pro CS6, CC, CC 2014 (v8.1 is not supported), CC 2015
Version 9.021 AE Release Note:
- Fixed a hang in Premiere CC 2015 when rendering on the GPU.
Release Name: GenArts Sapphire AE v9.0.2.1 CE Team V.R private build
Program Type: Video FX, Plug-in
Release Date: May 19, 2016
Interface Language: English
Requirements: Win64 / After Effects, Premiere Pro CS6-CC2015
Размер файла: 84.9Mb
