PRORUIN
PROLMK
Pixel Film Studios - FCPX Effect & Plugin Bundle (2013)
Большая коллекция различных, профессиональных эффектов и плагинов для Final Cut Pro X.
Просто перетащите нужный эффект на ваши кадры и измените настройки по своему вкусу.
Процедура установки:
Двойной клик на выбранном пакете, запустить установщик и следовать инструкции.
http://vimeo.com/pixelfilmstudios
PRO3DT http://vimeo.com/61214097
Create a cutting edge 3D title sequence directly in Final Cut Pro X with PRO3DT™ from Pixel Film Studios™. Adding 3D Text and logos to your FCPX project has never been so easy. With PRO3DT™, you can now give your Final Cut Pro X text depth and dimension with the click of a button.
PRO8MM http://vimeo.com/78739098
PROACTION http://vimeo.com/51013989
Create the next Hollywood blockbuster with PROACTION™ by Pixel Film Studios™. With 30 professional action color grades for FCPX, you can make your film project look like its ready for the big screen. Simply drop one of PROACTIONS’s™ effects on to your clip and adjust the user friendly controls to change the intensity and shadow. Headshot!
PROBOKEH http://vimeo.com/60709450
Want to give your footage a little bit of pop? How about some confetti? Perhaps a New Years kind of feel? Using PROBOKEH™ from Pixel Film Studios™ you can add those hazy, blurry, out of focus points of light that will give your footage the extra style it needs to turn your footage into a celebration! This plugin will come with different speeds to choose from. You will have the ability to add a gentle sprinkle of our PROBOKEH™ effect, or maybe you’ll prefer it slightly more aggressive.
PRODUB http://vimeo.com/58065154
PROFESSIONAL SEPARATION AND BPM EFFECTS
Create organized chaos with PRODUB™ from Pixel Film Studios™. Add screen separations, flashes, and prismatic effects to your footage to create energetic looks that will compliment your favorite electronic dance music. Simply drag and drop the effects on your footage and prepare to drop it hard!
PRODUST
With ProDust™ from Pixel Film Studios™, users can give their film an epic or magical look by simulating floating dust particles in their footage. ProDust™ is a collection of 100 ProRes dust composites that can be applied to footage in any non-linear editing software.
PROEXTREME http://vimeo.com/61923297
PROFESSIONAL EXTREME COLOR GRADES for Final Cut Pro X Need to create an extreme look in your next film project? With PROEXTREME™ from Pixel Film Studios™, you can take your footage anywhere from punk-psychedelic to action-packed in the click of a button. Create endless bold and aggressive looks in FCPX with PROEXTREME™’s collection of 100 intense color grades.
PROFILM http://vimeo.com/57390392
Turn your projects into a contemporary-styled film with PROFILM™ from Pixel Film Studios™. This collection of 30 film looks from Final Cut Pro X can instantly give your video a more cinematic feel. Apply color, darken shadows and add 35mm grain to transform your footage into a Hollywood film.
PROFIRE http://vimeo.com/62628252
PROFESSIONAL BURNING FIRE COMPOSITES
Want to add some roaring flame effects to your next film? With PROFIRE™ from Pixel Film Studios™ you can quickly and safely add fire effects to your next Final Cut Pro X project without burning down your studio. With 25 ProRes fire composites and a Final Cut Pro X Blending Tool, you can create some hot styles in your next film. Simply drag and drop a composite on top of your footage, change the blend mode and prepare to feel the heat!
PROFLARE http://vimeo.com/49118212
PROFESSIONAL LIGHT LEAKS FOR FCPX
Easily add beautiful, epic, or vintage lighting to any footage in FCPX with PROFLARE™ by Pixel Film Studios™, a collection of over 150 professional light leak effects. Simply drop one of PROFLARE’s™ effects on to your clip and adjust the user friendly controls to change the orientation, movement, color, flicker, and opacity of the light.
PROFOG http://vimeo.com/60106654
Add Fog to Your Footage
Want to give your footage a magical or Film Noire look? Adding fog or haze to your footage is a great way to create a mystical or ominous look in your film. With PROFOG™ from Pixel Film Studios™, you can choose from 50 ProRes fog video files that you can easily composite onto your footage. Simply drag one of the PROFOG clips ontop of your footage in any non-linear editing system and change the blend mode.
PROFRAG http://vimeo.com/65677368
Smash and shatter your footage into smithereens and watch as 3D fragments and shards made out of your footage fly by the camera. With over 30 presets to choose from, PROFRAG™ from Pixel Film Studios™ can help you make endless cool shatter effects in your next FCPX project. Simply insert a clip into one the PROFRAG™ drop zones and use the controls to shatter it appart!
PROFRAME http://vimeo.com/57806293
With PROFRAME™ from Pixel Film Studios™ you can add a realistic frame or border to your footage in Final Cut Pro X. PROFRAME™ comes with over 45 unique frames which can be manipulated in 3D space to create a parallax effect. Applying a frame to your film is a fun and easy way to add depth and style to your footage.
PROGRADE http://vimeo.com/51024785
PROFESSIONAL COLOR GRADES FOR FCPX Use color to change the mood and genre of your project with PROGRADE™ by Pixel Film Studios™. This collection of 30 professional color grades can be used in FCPX to create subtle yet powerful color changes. With PROGRADE’s™ easy-to-use controls, you can quickly adjust the intensity of the effect to achieve the perfect color grade for your scene.
PROHUD http://vimeo.com/62992519
PROFESSIONAL HEADS-UP DISPLAY ELEMENTS The two things that the future has promised us is flying cars and transparent touch screen surfaces. With PROHUD™ from Pixel Film Studios™, you can have one of them in your next futuristic Sci-Fi film by creating your very own Heads Up Display interface in FCPX. Simply drag and drop HUD elements into the timeline and stack them to create cool and unique looks right inside Final Cut Pro X.
PROLAROID http://vimeo.com/55982480
Professional Instant Photo Effects for FCPX
Have some beach footage or a family video that needs a timeless or vintage touch? With PROLAROID™ from Pixel Film Studios™, you can easily create the popular instant photo look with any footage in Final Cut Pro X. With 30 photo looks to choose from, along with customizable frames, artifacts, and film textures, the possibilities are endless!
PROLENS http://vimeo.com/52261874
Create the cinematic masterpiece you always wanted to with PROLENS™. This bundle of professional lens plugins and video enhancing tools for FCPX will help you look like a professional Cameraman. Use the plugins in PROLENS™ to give your footage optical looks that you could normally only achieve in-camera and by owning many expensive lenses.
PROLMK http://vimeo.com/64926132
PROFESSIONAL LOGO MASKING FOR FINAL CUT PRO X
Want to show video through your company’s logo? With PROLMK™ from Pixel Film Studios™, you can create video masks out of any logo cut out or shape and control the mask in 3D space directly inside of Final Cut Pro X. With 25 unique style and movement presets to choose from and customizable options, the possibilities are limitless.
PROLOGRAM http://vimeo.com/60026933
Professional Hologram Techniques
Want your footage to like its being transmitted from light years away? With PROLOGRAM™ from Pixel Film Studios™, filmmakers can take their green screen footage and create holographic projections in Final Cut Pro X. Simply scan the effects browser for the shade of green or blue that your screen is and drop it onto your footage.
PROLUMA http://vimeo.com/65754221
Professional Light Extractions for FCPX
Extract the light out of your image and manipulate it in Final Cut Pro X with PROLUMA™ from Pixel Film Studios™. This collection 50 light control presets gives you total control over the color and quality of the light in your scene. PROLUMA™ doesn’t composite a lighting effect over your footage; it works with the light in your footage!
PROLUMETRIC http://vimeo.com/56787103
PROLUMETRIC™ - PROFESSIONAL VOLUMETRIC LIGHTING EFFECTS
Want to give the illusion that epic or stunning light rays are poking through clouds or a stained glass window? With PROLUMETRIC™ from Pixel Film Studios create beautiful volumetric lighting effects in Final Cut Pro X.
PROMASK
PROMONO http://vimeo.com/58651312
PROFESSIONAL WASHED AND MONOCHROME FILM LOOKS Achieve that washed out film look that you always wanted with PROMONO™ from Pixel Film Studios™. This collection of 100 monochromatic and washed out color grades can help you create the stylistic theme and tone of your film. PROMONO™ was professionally designed to work inside of Final Cut Pro X.
PROMOOD http://vimeo.com/55136127
PROFESSIONAL COLOR PROCESSES FOR FCPX
Create the ambient feel of your film through color with PROMOOD™ from Pixel Film Studios™. This collection of 55 professional color processes was designed to beautifully and subtly change the mood of your footage in FCPX. Simply drag and drop one of PROMOOD’s color presets on to your image and see the emotion of your scene change instantly. Then use the easy-to-use controls into to achieve your desired look.
PROMORPHIC http://vimeo.com/58321970
PROFESSIONAL ANAMORPHIC TECHNIQUES
If your are filming a music video or Sci-Fi movie, Anamorphic lens flares are a great stylistic approach. With PROMORPHIC™ from Pixel Film Studios™, you can choose from up to 40 different anamorphic presets to add horizontal or vertical lens flares to the light sources in your footage.
PROPIXIE http://vimeo.com/59755127
PROFESSIONAL PARTICLE TECHNIQUES - FCPX Effects - Pixel Film Studios
With PROPIXIE™ from Pixel Film Studios™, you can give your film an epic or magical look by simulating floating particles in your footage. PROPIXIE™ is a collection of 75 ProRes composites that can be applied to footage in any non-linear editing software, simply drag and drop the video file on top of your footage in the timeline and select a composite type.
PROPLAY http://vimeo.com/62514532
Enjoy scrapbooking? Take your audience into the scene with PROPLAY™ from Pixel Film Studios™. With this collection of over 90 whimsical curtain, letter and shape effects, you can add some fun to your next title sequence or scene transitions in Final Cut Pro X. Simple place the PROPLAY™ effects on top of your footage or below text to create playful looks.
PRORUIN http://vimeo.com/60335697
PROFESSIONAL GRUNGE TECHNIQUES
Create the grungy, gritty film that you always wanted to with PRORUIN™ by Pixel Film Studios™. This collection of over 100 Final Cut Pro X presets and 50 video composites allows you to add moving textures, burns, splatters and colors to your film to give it that dynamic look. PRORUIN™ gives you a never seen before amount of control over your grunge effects in FCPX.
PROSHIVER http://vimeo.com/51644571
PROFESSIONAL MALFUNCTION EFFECTS FOR FCPX
Add a little chaos or tension to your next project with PROSHIVER™ by Pixel Film Studios™. This collection of over professional 60 malfunction effect will give any scene a more kinetic, fast paced feel.
PROSKIN http://vimeo.com/54462675
Achieve that perfect model look with PROSKIN 2.0™ for FCPX. With 30 professional skin retouching plugins, you will be able to smooth and soften your actors’ faces, no matter what skin tone they have. Make your actors happy by taking years off their faces while leaving their important facial features intact! With easy-to-use on-screen controls and sliders, removing unwanted wrinkles and blemishes has never been so easy.
PROSLICE http://vimeo.com/56662932
Whether you are editing a telephone conversation or reinventing the intro to the Brady Bunch, PROSLICE™ by Pixel Film Studios™ has the split screen settings for you. This collection of Final Cut Pro X plugins features 50 screen slice templates. With on-screen controls and 3D camera perspectives, PROSLICE™ provides a powerful and easy solution to split screen editing.
PROSMOKE http://vimeo.com/59437321
Filming an abandoned building or a bubbling bog? Create a mystical, smokey atmosphere with PROSMOKE™ from Pixel Film Studios™. This collection of 50 ProRes smoke composites can create a magical, chaotic or steamy look with any footage. PROSMOKE™ can be applied to clips in any non-linear editing software, simply drag and drop the video file on top of your footage in the timeline and select a composite type.
PROSNOW http://vimeo.com/80483169
From a light sprinkle to a flurry of flakes, PROSNOW™ from Pixel Film Studios™ lets you control your winter wonderland in Final Cut Pro X. With a new snow emitter generator system, you can customize and adjust the snowfall and blend settings more precisely than with composite footage.
PROSTATIC http://vimeo.com/63123352
Remember when you had to play around with the rabbit ear antennas or hit the side of the television set to get a clear picture? Now with PROSTATIC™ from Pixel Film Studios™ you can recreate the static effects of an old television or VCR in Final Cut Pro X. This collection of over 50 static effects can simulate everything from VCR tracking to a night time surveillance camera.
PROTERRA http://vimeo.com/64160805
Want to create a clean 3D environment to show off images and text? With PROTERRA™ from Pixel Film Studios™, you can create a stage for your action and then control a 3D camera and lights to illuminate your text and images from all angles in Final Cut Pro X. With this collection of 80 presets, you can make an impressive slide show presentation or corporate video with FCPX.
PROTMK http://vimeo.com/64322344
Want to make text out of your video? With PROTMK™ from Pixel Film Studios™, you can create text masks out of your images or clips and control the masks in 3D space directly inside of Final Cut Pro X. With 30 text movements to choose from and customizable options, you can create endless unique text mask looks.
PROTRACE http://store.pixelfilmstudios.com/plugin/protrace-plugin
Turn your FCPX video into a flip book cartoon, graphic novel, or painting with PROTRACE™ by Pixel Film Studios™. In the click of a button, trace your images with chalk, watercolor paint, or color pencils. With PROTRACE™ you can turn any film into a hand-drawn work of art.
PROVEGA http://vimeo.com/53122301
Add high-end lens flares to your next FCPX project with PROVEGA™ by Pixel Film Studios™. This collection of dozens professional lens flares was designed to create naturalistic streaks and light spots caused by light reflecting inside a camera lens. The PROVEGA™ flares are ready to be be animated and customized for your footage.
PROVINTAGE http://vimeo.com/50382327
Create a retro photograph look in your next project with PROVINTAGE™ by Pixel Film Studios™. This collection of 30 professional vintage color grading effects can be used seemlessly with FCPX. Make any footage into a timeless moment by simply applying the plugin to a clip. Then, use PROVINTAGE’s™ easy-to-use controls to adjust the intensity of the effect, giving your film a beautiful and trendy look.
PROVOGUE http://vimeo.com/49394000
PROFESSIONAL POP COLOR GRADES FOR FCPX
Achieve a smart and stylish look in your film project with PROVOGUE™ by Pixel Film Studios™, a collection of 50 professional pop color grading effects for FCPX. PROVOGUE™ can give your footage the luster and color of a professional fashion shoot. Simply drag and drop the plugin on to your footage and voilà! Your project is instantly glamorous.
PROWALL http://vimeo.com/63936361
Want to create a wall of monitors that are each showing a different clip or image? With PROWALL™ from Pixel Film Studios™ users can create video walls, rooms and tunnels directly inside of Final Cut Pro X, and then navigate the viewer through them with a 3D camera. With 60 different layouts and customization options, the possibilities are endless.
TRANSDUB http://vimeo.com/58989345
Add a little chaos to your next music video with TRANSDUB™ from Pixel Film Studios™. Flash, spin and seperate your way from one clip to the next creating awesome and energetic looks that will compliment your favorite dubstep music. Simply drag and drop the transitions between two of your clips and watch as the beat goes on!
TRANSFIRE http://vimeo.com/62204484
Need some explosive transitions for your next film? With TRANSFIRE™ from Pixel Film Studios™ you can quickly and easily add fire burst transitions to your next Final Cut Pro X project without sacrificying your camera, house or eyebrows. With 30 fire transtions to choose from, you can burn, blast and burst your way from clip to clip in the click of a button.
TRANSFLARE http://vimeo.com/57013946
PROFESSIONAL LIGHT LEAK TRANSITIONS FOR FCPX
Flicker, flash, and flare your way from one clip to the next with TRANSFLARE™ from Pixel Film Studios™. With 70 professional light leak transitions for Final Cut Pro X, you can create endless vintage, hip, or edgy looks. Easily add beautiful light transitions to your footage by dropping one of TRANSFLARE’s™ effects between two of your clip and adjust the user friendly controls.
TRANSHIVER http://vimeo.com/53722102
Create quick computer glitch transitions with TRANSHIVER™ from Pixel Film Studios™. With 45 professional malfunction transitions For FCPX, you can pixel shift and shiver your way from one clip to the next. TRANSHIVER™ transitions will give any scene a more kinetic, fast paced feel.
TRANSLINE http://vimeo.com/61815137
Create awesome and energetic transitions in FCPX with TRANSLINE™ from Pixel Film Studios™. With TRANSLINE™, you can follow streaking 3D lines made out of your footage from one clip to the next, creating a clean, spacey enviroment in your next Final Cut Pro X project. With 30 unique transitions to choose from, you can quickly and easily design a professional corporate video or rad music video in a matter of seconds.
TRANSTATIC http://vimeo.com/63432022
Wriggle, warp, and roll your way from one clip to the next with TRANSTATIC™ from Pixel Film Studios™. With over 50 professional static transitions for Final Cut Pro X, you can create endless thrilling, hip, or horrifying looks. Easily add realistic static transitions to your footage by dropping one of TRANSTATIC’s™ effects between two of your clip and adjust the length to your liking.
TRANSTELE http://vimeo.com/61389593
Create the illusion that your camera is passing through an old school CRT television screen with TRANSTELE™ from Pixel Film Studios™. With over 60 professionally made transitions to choose from you can make it look like your being sucked in or out of your tv screen. Simply drag and drop one of the the TRANSTELE effects between your clips, adjust the speed, and be amazed.
PROGRUDGE http://vimeo.com/69394338
Zoom your audience into a world of suspended dirt and grunge particles to create a tense and gritty viewing experience.
PROHDR http://vimeo.com/69928254
With this plugin you create the high dynamic look that is normally created by combining shots filmed at different exposures.
PROPANEL http://vimeo.com/76170045
You can camera track your text, customize each panel, choose your background, and control the camera angle of view.
PRORAIN http://vimeo.com/57702665
With 25 unique rain composites to choose from, take your footage anywhere from a light drizzle to a tropical rain forest in the click of a button.
PROSMOKE VOLUME 2 http://vimeo.com/78559554
Introducing Volume 2, a generator that allows you to freely change the look of realistic smoke.
PROTO http://vimeo.com/73090305
From instant photo effects to hipster grades to washed vintage looks, you can create every photographic look you could ever want in Final Cut Pro X with PROTO™ from Pixel Film Studios™. This collection of over 50 Photo filters can be applied, adjusted, and customized directy in FCPX. PROTO™ includes selective focus and frame styles to help you complete your photographic look.
PROVEGA Vol 3 http://vimeo.com/72502953
Create realistic, epic anamorphic lens flares in Final Cut Pro X. Volume 3 comes fully equipped with 30 new lens flare shapes and presets.
Pixel Film Studios - Text Effects for FCPX
PRO3RD
Professional Lower 3RD Titles for FCPX. Over 50 different lower thirds to choose from.
PRORACK http://vimeo.com/73744759
Create a contemporary and clean title sequence by racking focus between your image and your text in Final Cut Pro X.
PROTEASER VOL 1-2-3-4 http://vimeo.com/75612711
Get ready to create the hype for your next blockbuster film. This collection of unique teaser trailer texts can help you create an epic promotional video in Final Cut Pro X.
PROTEXT VOL 1-2-3 http://vimeo.com/71825085
Create Professional text title introductions for Final Cut Pro X with PROTEXT™ from Pixel Film Studios. Make a statement with your film title with these animation presets. Look like a pro with over 40 different animations to bring your title to life. Looking for two-dimensional or three-dimensional text animations in FCPX? The PROTEXT™ Volume 1 Plugin from Pixel Film Studios™ has you covered!
PROTRK http://vimeo.com/82414755
Create the text positioning effects you have always wanted in Final Cut Pro X. This plugin not only gives you the option to interact your text with your media, but also gives your text a whole new look.
PROTYPO http://vimeo.com/74644806
Say goodbye to keyframes and templates! Get ready to create real kinetic typography sequences in Final Cut Pro X without using a template or a single keyframe.
Pixel Film Studios - Themes for FCPX
CORPORATE CIRCUIT http://vimeo.com/66019784
Need a clean corporate template for your next board meeting? With Corporate Circuit from Pixel Film Studios™, you can customize and edit your presentation directly in Final Cut Pro X. Change the color theme, text, and images with in the FCPX Inspector without ever opening another application.
LIGHT GRID http://vimeo.com/66694308
Create a futuristic circuit board world with the Light Grid theme for Final Cut Pro X from Pixel Film Studios™. With glowing laser lights and sliding image panels, Light Grid can give your film cutting edge look. This theme allows you to quickly and easily customize the color, text, font and images directly inside the FCPX Inspector.
LINE CROSSED http://vimeo.com/66160672
Don’t make your next Final Cut Pro X film a fashion faux paus. With Line Crossed from Pixel Film Studios™, you can customize and edit the theme to match your style. Change the color, text and images directly inside the FCPX Inspector without ever opening another software or app.
THE SPOTLIGHT
Get ready to edit like a rockstar inside Final Cut Pro X.
Pixel Film Studios - Tools for FCPX
PROAXIS http://vimeo.com/67435747
Create interesting angles and perspectives in Final Cut Pro X with PROAXIS™ from Pixel Film Studios™. Pivot, rotate, and skew your footage with a 3D Camera. Then give your film a cinematic looks by adjusting the depth of field and lens angle. With on screen controls and easy to use sliders, controlling a 3D camera in Final Cut Pro X has never been so easy.
PROBLUR http://vimeo.com/70652255
Create artistic or practical blur effects with PROBLUR™ from Pixel Film Studios™, the ultimate selective blur plugin for Final Cut Pro X. Use the blur areas to cover up unwanted logos or licences plates or protect an eye witness’s identity. With over 40 blur presets, on-screen controls and customization options, PROBLUR™ can help you create any selective blur effect in FCPX.
PROHUE http://vimeo.com/69173215
Take total control over the color in your film like never before in Final Cut Pro X with PROHUE™ from Pixel Film Studios™. With 30 customizable presets, you can calibrate the colors, levels, temperature, saturation, cross processing, vignette, and wash to get exact color grade you want for your film in FCPX.
PROLEAK http://vimeo.com/66768232
PROLEAK™ from Pixel Film Studios™ allows you to take total control over your light leak in Final Cut Pro X. With on-screen controls and customizable options, you can manipulate and create the perfect light leak for your scene. Simply drag and drop one of the 30 PROLEAK™ presets on to your footage and prepare to control the light in FCPX!
PROPATH http://vimeo.com/73272506
Take your audience on a journey with PROPATH™ from Pixel Film Studios™. With this tool, You can create a camera path with up to five 3D camera movements in single shot without ever setting a single keyframe in Final Cut Pro X. Design smooth and complex paths by simply moving the on-screen controls in the Viewer Window. Then use the camera controls to change the angle and depth of field to create unique viewing perspectives.
PROSHAKE http://vimeo.com/67910919
PROFESSIONAL CAMERA SHAKE EFFECTS FOR FCPX
Whether you are making a fight promo, music video or tense espionage thriller, camera shakes are a great way to add a sense of reality to your film. With PROSHAKE™ from Pixel Film Studios™, you can create epic bumps, shakes, zooms, and twists right inside FCPX. With 50 presets and stackable effects, you can create endless unstabalized camera looks in a snap.
PROSLICE VOLUME 2 http://vimeo.com/74436406
Prepare to add some grungy flavor to your split screen scenes in Final Cut Pro X with PROSLICE™ Volume 2 from Pixel Film Studios™. With 50 hand drawn split screens layouts to choose, from you can easily drag and drop the one you want on your footage in FCPX. Then you can customize the color, lens dirt, and discoloration of your split screen.
Pixel Film Studios - Transitions for FCPX
TRANSPEEL http://vimeo.com/68889147
OVER 35 PRESETS
Create every peel transition you could ever want with TRANSPEEL™ from Pixel Film Studios™. With over 35 presets, 9 styles, and customization options, the peeling possibilites are endless. Simply scrub over the TRANSPEEL™ transitions in the effects browser and see a preview in real time.
Потихоньку буду закачивать:
Pixel Film Studios - FCPX Brush Glow
FCPX 10.4.7
Содержимое закинуть в - Фильмы>Motion Templates>Generators
[i]
This plugin requires Final Cut Pro 10.4.5 and Mac OS 10.14. This plugin will not operate on only Late 2013 Mac Models with INTEL or AMD FirePro D300-D500 graphic cards.
[/i]
