Обычный пресет
matrix: cinema, все нули
color correction:
setting: on
target phase: 139
target width: 40
level: 0
phase: 0
white:
offset white: off
preset white: 6200
detail:
setting: on
level: +12
frequency: +20
crispening: -7
h/v ratio: 0
white limiter: 0
black limiter: 0
v dtl creation: NAM
knee apt level: +10
skin tone detail: выключен
gamma: cine1, level: 0
black: -6
black gamma: 0
low key sat: 0
Пресет при съёмке на солнце:
matrix: standard, все нули
color correction:
setting: on
target phase: 139
target width: 40
level: 0
phase: 0
white:
offset white: off
detail:
setting: on
level: +12
frequency: +20
crispening: -7
h/v ratio: 0
white limiter: 0
black limiter: 0
v dtl creation: NAM
knee apt level: +10
gamma: cine4, level: 0
black: -4
black gamma: 0
low key sat: 0
Пресет Филиппа Блюма
Matrix ……………on
Select…………….hisat
Level………………0
Phase……………-5
R-G…………………75
R-B…………………0
G-R…………………-18
G-B…………………-32
B-R…………………-27
B-G…………………13
Color Correction…………off
White…………………………off
Detail…………………………on
Detail Level…………………0
Detail Freq…………………0
Skintone……………………off
Knee…………………………on
Auto knee…………………on
Point…………………………90
Slope…………………………0
Knee SAT level…………50
Gamma Level…………-8
Gamma Select………….CINE1
Black………………………-12
Black Gamma……………0
Пресет от Lavelass
Matrix - Cinema
Level +15
phase +7
Detail ON
Level +5
Frecuency +3
Crispening +15
Gamma - STD3
LEVEL 0
KNEE
Auto knee OFF
point -85
slope 0
KNEE low SAT 0
Black 0
Black gamma 0
Пресет от vladvid
Matrix: High SAT
detail: On
Knee: On, Auto Knee - Off, Point - 90, Slope - +35, Knee SAT Level - 50
gamma: STD3
black: 3
Black gamma: -20
Пресет от Octus
Matrix Hi-sat
level +0
phaze +7
R-G R-B G-R G-B B_R B-G = все параметры + 20
Color correction
level +27
phaze +17
Detail off
Gamma CINE4
Black -4
blackgamma - 17
Low key sat 0
PP for TV Commercial
Matrix …on
Select…hisat
Level…0
Phase…-5
R-G…75
R-B…0
G-R…-18
G-B…-32
B-R…-27
B-G…13
Color Correction…off
White… off
Detail…On, Level 0, Frequency +65 (test 30/40), Crispening 0 (test 20/30), Black limiter +75, White limiter +75
Detail Level…0
Detail Freq…0
Skintone…off
Knee…on
Auto knee…on
Point…90
Slope…0
Knee SAT level…50
Gamma Level…0 (test until -40)
Gamma Select…CINE1 if sunny day / CINE3 if cloudy!
Black…-4, test up to -8/10
Black Gamma…-2
Low Key Sat: 0
Пресет от Glory
GLORY
Пресеты для последующего сведения Sony PMW-EX1R (1, 3) и Canon 5D Mark II
Стиль Canon 5D Mark II:
стиль изображения: Натуральное
резкость по вкусу у меня - 4
контрастность - 0
Насыщенность - 2
Цветовой тон +2
Стиль для Sony PMW-EX1R(1, 3):
Matrix: on
Select: Standard
Level: -14
Phase: +4
R-G: 0
R-B: 0
G-R: +8
G-B: 0
B-R: +14
B-G: 0
Gamma Level: 0
Gamma Select: STD1
Black: -4
Black Gamma: 0
В меню 1R (1) зайти в пункт LCD/VF, затем в LCD выставить параметры:
Color -23
Contrast 0
Brightness +18
(Для EX3 яркость и контрастность выставляются на видоискателе.)
Настройка проведена при снятии одного и того же объекта съёмки.
Внимание! Если будите подгонять цвета на EX под Mark то нужно сбросить настройки в LCD/VF по нулям, по окончании снова выставить как написано выше.
На самом корпусе яркость стоит максимальная (LCD Bright).
Wolfgang Picture Profile at -3dB (EX1R)
Matrix:
Setting: on
Select: FL Light
Level: +24
Phase: +4
R-G: -4
R-B: -17
G-R: +4
G-B: +11
B-R: +2
B-G: -6
Color Correction: off
White:
Offset White: on
Offset <A>: 0
Offset <B>: 0
Offset <ATW>: 0
Preset White: 5600
Detail:
Setting: on
Level: -30
Frequency: -87
Crispening: -80
H/V Ratio: +25
White limiter: 0
Black Limiter: 0
V DTL Creation: NAM
Knee APT Level: -45
Skin Tone Detail: off
Knee:
Setting: on
Auto Knee: on
Knee SAT Level: 28
Gamma:
Level: 0
Select: STD3
Black: 0
Black Gamma: -5
