GraniteBay
GraniteBay GBDeflicker v4.0.4 CE for After Effects and Premiere Pro CC2015
GBDeflicker - Плагин для After Effects, Premiere Pro и Premiere Elements, предназначенный для удаления покадрового мерцания. Мерцание может быть удалено в большинстве случаев, просто применив настройки GBDeflicker по умолчанию для вашей композиции.
GBDeflicker Benefits:
  • Analyzes your composition to detect and smooth out abrupt changes in luminance to create a flicker-free video
  • Flicker can be removed in most cases by simply applying GBDeflicker’s optimized default settings to your composition
  • User-friendly interface makes navigation and processing simple for amateurs and professionals
  • Rich controls and displays allow for total customization in the analysis and processing of your sequence beyond the default settings
  • Clear display graphs track input, output, settings, luminance and histogram results and provide clipping alerts throughout processing
  • Available as both an Adobe plug-in for After Effects and Premiere Pro and as a standalone Windows application
  • Adobe Plug-In: Windows and Mac compatible
  • The plugin version deflickers any input source After Effects can use load as input
  • The Windows application version imports sequences of Canon RAW files in addition to .jpeg, .gif, .png, .bmp and .tif files and processes them in a matter of minutes
  • Windows Application: Provides a quick look of your work by producing an output video (.mp4) of your image sequence without the need to run other video programs
Features:
  • Frame by frame histogram display with clipping alerts
  • Luminance graph indicating degree of flicker
  • Smoothing or Keyframe luminance correction algorithm
  • Optional linear or gamma correction
  • Optional analysis sub-rectangle
System Requirements
  • Windows 7, 8 (64-bit)
  • After Effects CC 2015 Only
  • Adobe Premiere Pro CC 2015 Only
Release Name: GraniteBay GBDeflicker v4.0.4 CE Team V.R private build
Program Type: Video Plug-in
Release Date: Jun 03, 2015
Homepage
Interface Language: English
Platform: Win64, After Effects, Premiere Pro CC 2015 Only
Размер файла: 4.5Mb
теоретически его можно применять к видео, снятому с частотой не 50гц для смягчения мерцания ламп освещения. надо попробовать.
GraniteBay GBDeflicker v3.0.11 CE for After Effects and Premiere Pro CC2015
GBDeflicker 3 - Нужный плагин для тех кто занимается цифровым видео, включая и его монтаж. Каждый из нас сталкивался с такой проблемой как мерцание видео картинки, особенно это заметно после цветокоррекции. С плагином GBDeflicke эта проблема останется в прошлом, ваше видео избавится от подобных артефактов, картинка будет ровной и после вторичной цветокоррекции. Устанавливается плагин легко, инсталлируем, запускаем к примеру премьер, сразу появится табличка с предложением активировать, дальше все понятно. Кстати не забудьте выключить сетевую карту.
Мерцание является распространённой проблемой в процессе работы с материалом, отснятым на фотокамеру, при замедленной или покадровой съёмке. Изменения освещения или экспозиции от кадра к кадру приводят к заметным колебаниям яркости или мерцанию. GBDeflicker, доступный в качестве подключаемого модуля к Adobe After Effects и Premiere Pro CS5, CS5.5, CS6 и CC, поможет удалить мерцания от кадра к кадру.
Compatibility
Adobe Plugin for Mac or Windows Adobe After Effects CC, CS6
Adobe Premiere Pro CC, CS6
Mac Version requires OS X 10.8 or newer
Release Name: GraniteBay GBDeflicker v3.011 CE Team V.R private build
Release Date: Jan 29, 2014
Platform: Win64, After Effects, Premiere Pro CS6/CC
Размер файла: 4,71 Mb
Я так понял это от резких изменений яркости видео, от кадра к кадру. А для того, что бы убрать мерцания лампочек и сведодиодов я применяю очень хороший плагин от BBC Flicker fixer. Убирает качественно, но сильно грузит машину. По этому я сначала монтирую, потом крашу, а потом накидываю его там где надо.
GraniteBay GBDeflicker v4.2.0 CE for After Effects and Premiere Pro
Features:
System Requirements
  • Windows 7, 8, 10 (64-bit)
  • After Effects CC 2015 & CC 2017 only
  • Adobe Premiere Pro CC 2015 & CC 2017 only
Release Name: GraniteBay GBDeflicker v4.2.0 CE Team V.R private build
Release Date: Jan 17, 2017
Platform: Win64, After Effects, Premiere Pro CC 2015 & CC 2017 only
Размер файла: 4.5Mb
