Nik Software
Nik Software Complete Collection (WIN/MAC)
Nik Software Complete Collection - this is the most complete collection of plug-ins from one of the best manufacturers of plug-ins for Adobe Photoshop. Complete Collection includes the complete set of plug-ins for Adobe Photoshop, Lightroom and Aperture including: Dfine, Viveza, HDR Efex Pro, Color Efex Pro, Silver Efex Pro and Sharpener Pro. With these plugins you can adjust the sharpness of images in digital photos, perform color correction, retouching, styling, getting rid of any type of noise in the picture, brightness, adjust contrast and color saturation of individual objects or areas of the photograph.
Set of plugins Nik Software for Adobe software for Windows:
  • Nik Software Sharpener Pro 3.007
  • Nik Software Color Efex Pro 4.001
  • Nik Software Silver Efex Pro 2.003
  • Nik Software Viveza 2.006
  • Nik Software Dfine 2.109
  • Nik Software HDR Efex Pro 1.202
  • Nik Color Efex Pro CE for Nikon Capture NX2 3.004
Set of plugins Nik Software for Adobe software under Mac OS X:
  • Nik Software Sharpener Pro 3.006
  • Nik Software Color Efex Pro 4.000
  • Nik Software Silver Efex Pro 2.001
  • Nik Software Dfine 2.108
  • Nik Software HDR Efex Pro 1.200
System requirements:
Windows
Windows ® XP, Windows Vista ® and Windows 7
AMD or Intel ® processor
2 GB RAM available (4 GB or higher recommended)
32-bit and 64-bit compatible
Required Host Applications to Use this Plug-In
Adobe ® Photoshop ® CS3 through CS5 **
Adobe Photoshop Elements 8 through 9, apart from HDR Efex Pro
Adobe Photoshop Lightroom ® 2.6 through 3.0 or later
Apple ® Aperture ® 2.1.4 through 3.1 and later
Please note:
** For HDR Efex Pro extended Edition required for 32-bit per channel Smart Object support.
  • Silver Efex Pro will not work on images in the grayscale color mode.
Macintosh
Mac ® OS 10.5.8 through 10.7, apart from HDR Efex Pro, which support Mac OS 10.5.8 and 10.6.x
Intel ® processor
Битность: 32bit +64 bit
Compatibility with Vista: complete
Compatible with Windows 7 full time
Language: ML / ENG
Таблетка: Present
Размер файла 1.13 GB
Скачать
Google Nik Collection 1.1.0.9
Google Nik Collection — это наиболее полная коллекция плагинов от одного из лучших производителей плагинов для Adobe Photoshop. Complete Collection включает в себя полный набор плагинов для Adobe Photoshop®, Lightroom® and Aperture® including: Dfine® , Viveza® , HDR Efex Pro™, Color Efex Pro™, Silver Efex Pro™and Sharpener Pro™ . С помощью этих плагинов вы сможете настроить четкость изображения на цифровых фотографиях, выполнить цветокоррекцию, ретуширование, стилизацию, избавиться от любого типа шума на фото, яркость, настроить контрастность и насыщенность цвета отдельных объектов или областей фотоснимка.
Набор плагинов Google Nik Collection для программ Adobe под Windows:
• Analog Efex Pro 1.009
• Color Efex Pro 4.309
• Dfine 2.209
• HDR Efex Pro 2.209
• Sharpener Pro 3.109
• Silver Efex Pro 2.209
• Viveza 2.109
Sharpener Pro™ — профессиональный плагин для Adobe Photoshop, с богатым набором новых возможностей, реализованных в обновленном продукте, позволяет выполнять огромный спектр задач – от предварительной коррекции резкости в файлах RAW, полученных с фотокамер, до финального увеличения резкости с учетом особенностей технологии вывода изображения. Позволяет работать с 16-битными изображениями без необходимости их перевода в 8-битные. Область предварительного просмотра позволяет вам во время работы видеть, как изменяется качество фотографии в зависимости от примененных эффектов.
Возможности плагина:
Создание точного и избирательного контроля резкости
Oбновленный механизм финальной корректировки резкости позволяет готовить изображения к выводу практически на любых устройствах и носителях – на экране мониторов, на струйных принтерах, в полноцветной полиграфии, шелкографии и т.д.
Увеличение резкости мелких деталей и текстур с новой структурой, фокусом, и местных отличий инструментов для привлечения внимания к желаемым областям изображения.
Color Efex Pro™ Complete Edition — большой набор фотографических фильтров для Adobe Photoshop, которые предназначены для улучшения ваших цифровых фотографий. В состав пакета входит 52 фильтра и 250 различных эффектов. Они помогают выполнить цветокоррекцию, ретуширование и многие другие операции. Интерфейс пакета выполнен в стиле плагина DigitalFilmTools с возможностью увеличения размера окна и просмотром изображений до и после применения выбранных фильтров и эффектов.
52 фильтра и 250 различных эффектов для улучшения фотографий
Уникальная технология U Point позволяющая гибко корректировать отдельные участки изображения
Новые фильтры: Film Grain, Film Effect, Glamour Glow, Selective Contrast, High Key, Low Key, Polaroid Transfer, Cross Balance
Инструмент выделения (Selective tool), позволяющий применять эффект только к выделенной области изображения
Nik Software Color Efex Pro™ filters are the leading photographic filters for digital photography. 52 photographic filters with over 250 effects for professional quality images. Now includes compatibility with Photoshop and Capture NX 2.
Silver Efex Pro — превосходный плагин для Adobe Photoshop, позволяющий фотохудожникам выполнять стилизацию современных цифровых изображений под стильные черно-белые снимки. В автоматическом режиме, программа преобразует цветное изображение в черно-белое. После этого пользователь может выполнить более тонкую настройку, например, выбрать один из двух десятков готовых стилей, воспользоваться фильтрами цветности и другими инструментами.
Быстрая стилизация цветных изображений в черно-белые в автоматическом режиме
Использование встроенных фильтров цветности
Настройка яркости, контраста и структуры изображения
Использование готовых пресетов
Viveza 2 – превосходный плагин, расширяющий функциональность набора инструментов для редактирования цифровых изображений в Adobe Photoshop. С помощью этого приложения пользователи смогут регулировать яркость, контрастность и насыщенность цвета отдельных объектов или областей фотоснимка. Программа самостоятельно выделяет нужные объекты и создает маски в автоматическом режиме, тем самым позволяя специалистам трудиться более продуктивно. (х64 только в этой новости)
Регулировка яркости, контраста и насыщенности выделенной части изображения
Уникальная технология U Point, позволяющая гибко корректировать отдельные участки изображения
Интеграция Smart-объектов в Adobe Photoshop
Предварительный просмотр результатов на экране перед печатью.
Dfine 2 — потрясающий плагин для Adobe Photoshop, позволяющий избавиться от шума любого типа на ваших фотографиях. Секрет фильтра заключается в том, что он помогает определить источник возникновения артефактов и на основе этой информации предлагает варианты решения проблемы. Всего за несколько кликов мышью программа позволит избавить фотографию от шумов в автоматическом режиме, кроме того, вы сможете самостоятельно настроить параметры для более оптимального результата.
Автоматическое удаление шумов с фотографии
Настройка параметров вручную для более оптимального результата
Подключаемые профили для каждого типа фотокамер
HDR Efex Pro, инструмент для создания HDR (High Dynamic Range) изображений. Создан в помощь фотографам профессионалам и любителям для быстрого и легкого улучшения полного спектра HDR. Новый HDR Efex Pro преодолевает ограничения существующие в других аналогичных программах с революционным подходом “все-в-одном”, который позволяет создавать реалистичные и художественные эффекты в рамках одного инструмента.
Системные требования
Adobe Photoshop CS4 through CS6
Adobe Photoshop Elements 9 through 11 (apart from HDR Efex Pro 2, which is not compatible with Photoshop Elements)
Adobe Photoshop Lightroom 3 through 5
Год выхода: 2013
Версия: 1.1.0.9
Платформа: Windows Vista®, Windows 7, Windows 8
Язык интерфейса: English
Таблетка: FIX, thx VVK
Скачать
Google Nik Software Complete Collection 1.2.8
Набор плагинов Nik Software для программ Adobe под Windows:
Analog Efex Pro 2.08.486
Color Efex Pro 4.3.20.486
Dfine 2.2.20.486
HDR Efex Pro 2.2.20.486
Sharpener Pro 3.1.20.486
Silver Efex Pro 2.2.20.486
Viveza 2.1.20.486
Analog Efex Pro — программа(плагин) предназначенная для серьезных фотографов, в которой можно будет применить различные оптические, винтажные эффекты, создавать профессионально стилизованные изображения, выбрав нужные вам пресеты имитирующие кино и фотопленку и производить тонкую конечную настройку. Регулируйте боке, текстуры, рамки и другие элементы, точно определяя местоположение ваших эффектов на изображении.
Sharpener Pro — профессиональный плагин для Adobe Photoshop, с богатым набором новых возможностей, реализованных в обновленном продукте, позволяет выполнять огромный спектр задач – от предварительной коррекции резкости в файлах RAW, полученных с фотокамер, до финального увеличения резкости с учетом особенностей технологии вывода изображения. Позволяет работать с 16-битными изображениями без необходимости их перевода в 8-битные. Область предварительного просмотра позволяет вам во время работы видеть, как изменяется качество фотографии в зависимости от примененных эффектов.
Обновленный механизм финальной корректировки резкости позволяет готовить изображения к выводу практически на любых устройствах и носителях – на экране мониторов, на струйных принтерах, в полноцветной полиграфии, шелкографии и т.д.
Color Efex Pro — большой набор фотографических фильтров для Adobe Photoshop, которые предназначены для улучшения ваших цифровых фотографий. В состав пакета входит 52 фильтра и 250 различных эффектов. Они помогают выполнить цветокоррекцию, ретуширование и многие другие операции. Интерфейс пакета выполнен в стиле плагина DigitalFilmTools с возможностью увеличения размера окна и просмотром изображений до и после применения выбранных фильтров и эффектов.
Viveza 2 — плагин, расширяющий функциональность набора инструментов для редактирования цифровых изображений в Adobe Photoshop. С помощью этого приложения пользователи смогут регулировать яркость, контрастность и насыщенность цвета отдельных объектов или областей фотоснимка. Программа самостоятельно выделяет нужные объекты и создает маски в автоматическом режиме, тем самым позволяя специалистам трудиться более продуктивно. (х64 только в этой новости)
HDR Efex Pro — инструмент для создания HDR (High Dynamic Range) изображений. Создан в помощь фотографам профессионалам и любителям для быстрого и легкого улучшения полного спектра HDR.
Интуитивно понятный интерфейс, с простой понятной фотографической терминологией и постоянным отображением фактических результатов обработки.
Мощный селективный инструмент U Point ® для быстрой и точной настройки контраста, тени, структуры и корректировки насыщенности.
Несколько собственных Tone Mapping алгоритмов, предоставляющих широкий спектр стилей, и HDR возможностей
Мощное управление настройками пресетов , которые дают несколько стилей HDR — от реалистичного фото до креативного
Стандартные и пользовательские предустановки разбиты по категориям для работы в один клик мыши.
HDR из многократно экспонированных фото или по одному кадру
Передовая технология для автоматического выравнивания изображений и сокращения артефактов известных как “призраки”.
Все-в-одном позволяет из фото с 32-битным цветом создавать профессиональные изображения HDR.
Что нового:
Version number format changed, and added to all splash screens
Improved loading speed
Added option to send anonymous usage statistics to Google
Added Adobe Photoshop Elements 13 support
Fixed potential crash at startup related to GPU
Fixed potential crash related to unavailable screen color profiles
Fixed issues that could happen when loading very large images
Fixed issues related to TIFF file handling
Fixed issue with plug-ins in remote desktop sessions
Fixed potential crash during software rendering
Analog Efex Pro 2: on-image editing in Double Exposure has been updated
Analog Efex Pro 2, Color Efex Pro 4, Silver Efex Pro 2: Lightroom metadata hierarchy is now preserved
Analog Efex Pro 2, Silver Efex Pro 2: fixed tiling and banding artifacts in specific setting combinations
Color Efex Pro 4: fixed potential Photoshop crash caused by broken XML files
HDR Efex Pro 2: fixed image display issue when toggling control point masks on and off
HDR Efex Pro 2: fixed alignment issue for exposure series
HDR Efex Pro 2: fixed an issue with Control Points being non-editible in Smart Objects
Silver Efex Pro 2: fixed CMD+F/CTRL+F shortcut within Photoshop for re-applying previous filter effect
Windows Vista / 7 / 8
Adobe Photoshop CS4 – CC 2014
Adobe Photoshop Elements 9 – 12 (отдельно от HDR Efex Pro 2, так как не совместим с Photoshop Elements)
Adobe Photoshop Lightroom 3 – 5
Совместимые GPU:
NVIDIA GeForce 8 Series, GeForce 9 Series, GeForce 100 Series, GeForce 200 Series, GeForce 300 Series, GeForce 400 Series, GeForce 500 Series, ATI Radeon HD2000 Series, Radeon HD3000 Series, Radeon HD4000 Series, Radeon HD5000 Series, Radeon HD6000 Series.
Если используется несовместимая видеокарта, GPU акселерация будет отключена и передана центральному процессору.
Язык интерфейса: Русский, Английский и другие
Лечение: в комплекте
Тип лекарства: патч
Процедура лечения:
Установите программу.
Скопируйте файл из папки Crack в папку с установленной программой и запустите его с правами администратора.
http://www.ex.ua/632269264127
https://cloud.mail.ru/public/54978133a74a/Google%20Nik%20Software
