Плагины от Aescripts
Aescripts: Keysmith v1.1 for After Effects
Keysmith - Скрипт для After Effects, который предоставляет методы для манипулирования ключевыми кадрами и свойствами каналов в компактном интерфейсе.
ome main features Keysmith provides:
  • A condense and dockable panel the blends in with native After Effects panels.
  • Change the values of multiple keyframes and property channels simultaneously.
  • Precisely modify values with relative or absolute values.
  • Copy the value of selected keyframes or from current time.
  • Save the current state of the UI for use later.
  • Generate multiple new keyframes with new values already set.
  • Treat position properties that have been separted as one keyframe.
  • Affect only specifed axes in properties that have multiple dimensions.
  • Change the speed and influence of keyframes.
  • Modify the spatial interpolation of keyframes.
  • Optional multiply the length of default tangent handle.
  • Quickly set roving and hold keyframes.
  • Smart input fields accept values such as: 1in, 1ft, 1cm, 1mm, 1% and converts accordingly. Default unit is pixels.
Compatibility: After Effects CC, CS6, CS5.5, CS5, CS4
Changes in v1.1:
  • Fixed bug where shape where certain shape layer properties were ignored.
  • Added multiply, divide, subtract buttons.
  • Removed invert button in favor of the new subract button.
  • Removed Sep checkbox, separate dimensions is always assumed.
  • Color values are now not normalized, e.g. red is 1, 0, 0.
  • Refocus to active comp after operation in CS6 and above.
  • Improved number input handling.
  • Fixed dropdowns not showing values in CS4.
  • Fixed font issue.
Release Name: Aescripts: Keysmith v1.1
Release Date: Jun 2013
Homepage
Interface Language: English
Requirements: After Effects CS3 - CC
Размер файла: 31.6Mb
Aescripts: Automated Video Editing v1.03 for After Effects
Automated Video Editing позволяет автоматизировать в After Effects процесс редактирования видео в соответствии с музыкальным ритмом и другими правилами, которые вы применяете. Импортируйте видеоклипы и музыку, сделайте некоторые простые настройки и получите полностью редактированное видео, синхронизированное с музыкой, которая может быть легко скорректирована, если необходимо. Тем самым вы сэкономите время, которое потратили бы на ручное редактирование видео для промо, вечеринки, VJ-видео, свадьбы и многого другого…
Возможности скрипта:
  • Автоматическое редактирование видео в ритм музыки (с контроллером чувствительности).
  • Варианты случайного выбора видео кадров.
  • Повторение параметров видео.
  • Опция ограничения продолжительности кадров (минимальная продолжительность, максимальная продолжительность).
  • Настройка размера композиции и частоты кадров
  • Опция масштабирования для всех слоёв в зависимости от размера композиции.
  • Коррекция цвета и стили.
  • Генератор анимации названий для открытия и закрытия.
Release Name: Aescripts: Automated Video Editing v1.03
Program Type: After Effects Plug-ins
Release Date: Jun 7, 2015
Homepage
Requirements: After Effects CC 2014, CC, CS6
Размер файла: 16Mb
Aescripts: ft-Lens Distortion v7.1 for After Effects and Premiere
ft-Lens Distortion - Плагин для After Effects и Premiere, что позволяет быстро и легко производить коррекцию искажений объектива или эффектов, включая хроматическую аберрацию.
Release Name: Aescripts: ft-Lens Distortion v7.1
Release Date: Oct 2012
Homepage
Requirements: After Effects / Premiere CC, CS6, CS5.5, CS5, CS4
Размер файла: 10.6Mb
Aescripts: Vigoro v1.0 for After Effects
Vigoro - Мощный, хорошо настраиваемый инструмент для After Effects, предназначенный для создания удивительных анимаций, что может занять несколько часов или дней, если это настраивать традиционно. Вы можете создать целый ряд анимаций - от простых меток, переходов, до полных иллюстраций!
Features:
  • Offsets: You can offset time, scale, rotation and a whole host of other things to make really fluid, complex animations with as few as 2 keyframes!
  • Colors: Colors of your layers can changed really simply by selecting the top and bottom colors, and letting Vigoro do the rest. However, if you want to get a little more in-depth, you can sample layers for your fill and stroke. Make complicated gradients, animate them, add more gradients or effects, and make it as detailed as you want!
  • Cut Effects: Want to spice up your animation a little more? 5 different Cut Effects allow for a huge variety of looks, and each has a multitude of options to play with!
  • Distribution: Easily distribute your layers! You can offset radially or linearly, and 3D distributions are fully supported.
  • Speed Modifiers:v The Speed Modifiers will let you use the velocity of existing keyframes to add additional transformations and movement to your animation without having to keyframe them!
  • [i]Cloner: Repetition gets a bad rap, but sometimes it can add a lot! Clone your shapes and offset the clones to create amazingly complex compositions.
  • Text Layers: Use text layers and breathe a whole new life into your animations - use distributions and cuts, or wiggle the text around for some really cool effects.
  • Convert Layers:v Use precomps, videos, images or more in your Vigoro animations!
  • [i]3D Layers: In Vigoro, each layer is set up ready for 3D use, and alongside the flexible compositions you can add cameras, lights or whatever else you might want!
  • Custom Layer Controls: You can now individually adjust each layer, to allow for an ever greater breadth of possibilities. Want to make that layer go a bit off to the side? Or change the color? Or arrange layers into pictures? No problem! Just choose the layer you want, and make adjustments in the Effects panel.
Users Interface:
  • Dockable UI Panel: Choose your composition name, set options, and always have it ready to go when you need to create a new Vigoro Composition!
  • Easy Default Settings: Set defaults for your Vigoro Compositions so your compositions will always be created as you want them.
  • Flexible Compositions: Each composition is created with a ‘stack’ of Vigoro Layers, with layers to mark the start and end of the stack. Outside of those layers, you can do whatever you want! Add backgrounds, text layers, cameras, adjustment layers or whatever else you might want! It’s a great way to speed up your workflow.
  • Bake/Freeze Panel: Bake and freeze your compositions to speed up your project! Easily choose which aspects of your composition you want to freeze, lock layers to keep them safe, and bake away! The Bake/Freeze panel works outside of Vigoro as well, so you can use it wherever you need!
Compatibility: After Effects CC 2014, CC, CS6
Release Name: Aescripts: Vigoro v1.0
Release Date: Jan 22, 2015
Homepage
Размер файла: 41.8Mb
Aescripts: Orient World v1.2 for After Effects
Orient World - В сценах, отслеживаемых в After Effects с использованием встроенного трекера 3D-камеры, плоскость земли в сценах в большинстве случаев заканчивается как наклонная плоскость в 3D-пространстве. Orient World исправляет это - одним щелчком мыши вы можете сделать твердый слой заземления вашей сцены и ориентировать всё соответственно. Вместо установки горизонтальной плоскости, вы также можете выровнять сцену на стенах. Для еще большей настройки вы также можете вручную перемещать, вращать и масштабировать систему координат в 3D-пространстве. Кроме того, Orient World предлагает интуитивно понятную визуализацию центра пространства, которую вы можете включить или выключить одним кликом.
Compatible:
  • After Effects CC 2014, CC, CS6, CS5.5, CS5, CS4
Changes in Version 1.2:
  • Updated user interface to match new CI
Release Name: Aescripts: Orient World v1.2
Release Date: Sep 2, 2013
Homepage
Requirements: After Effects CS4 - CC 2014
Размер файла: 27.3Mb
Aescripts: Explode Shape Layer v3.0 for After Effects
Explode Shape Layers 3 - Скрипт для After Effects, предназначенный для управления формами слоёв, позволяющий разрывать или соединять их с высокой точностью. Кроме этого скрипт имеет много других инструментов!
Вы имеете дело с большим количеством форм слоёв, или формами слоёв из Adobe Illustrator? Explode Shape Layers позволит разделить каждую фигуру из формы слоя в её собственный индивидуальный слой для более точного управления и более лёгкого доступа. Кроме того, вы можете объединить несколько форм слоёв вместе в новом слое!
Надоело кликать правой кнопкой мыши на .ai-слой, чтобы сделать его в форме слоя? Используйте для преобразования Explode Shape Layers!
https://www.youtube.com/watch?v=vb_Fsjg5FTE
Features:
  • Explode - Explode a shape layer to individual layers
  • Merge - Merge shape layers together to a new layer
  • Convert - Convert Vector to Shape Layer
  • Remove Artboards - Removes AI artboard artifact
  • Select Fills - Select all fills in active comp
  • Select Strokes - Select all strokes in active comp
New in v3.0:
New buttons:
  • Convert, convert a vector layer to a shape layer
  • Remove Artboards, for use after converting a vector layer to a shape layer
  • Select Fills & Select Strokes, for selecting all fills or strokes in the active comp
    Revised UI:
  • New toolbar layout
  • Responsive design! Resize the panel to fit your layout
  • Show or hide any buttons you want
  • Switch between graphic & text buttons
  • Help text in options panel
    Fixes & Updates:
  • Revised the way Merge & Explode work, with respect to ‘Use All’ – see above!
  • Updated headless modifier controls to implement new explode & merge features
  • Added progress bars, so you can watch the magic happen!
  • Merge now works with animated properties
  • Major bug with Merge resulting in empty layers fixed!
  • Many bug fixes and under-the-hood code tweaks
Compatibility: After Effects CC 2014, CC, CS6, CS5.5, CS5
Changes in Version 3.0:
  • New tools, new UI, lots of bug features and minor tweaks
Release Name: Aescripts: Explode Shape Layer v3.0
Release Date: Feb 1, 2015
Homepage
Requirements: After Effects CC 2014, CC, CS6, CS5.5, CS5
File Size: 8.8Mb
Aescripts: Power Cylinder v1.0.0 for After Effects
Power Cylinder - Плагин для After Effects, предназначенный для создания и настройки 3D-цилиндра, предоставляет мощное управление эллиптическим искажением, разворотом, затенением, отражением, глубиной резкости, освещением и камерой.
Compatible:
  • CC 2014, CC, CS6, CS5.5, CS5
Changes in Version 1.0.0:
  • Initial release
Release Name: Aescripts: Power Cylinder v1.0.0
Release Date: Jan 30, 2015
Homepage
Размер файла: 8.8Mb
Aescripts: Power Sphere v1.1.0 for After Effects
Power Sphere - Плагин для After Effects, предназначенный для создания 3D-сферы, предоставляет мощное управление эллиптическим искажением, разворотом, затенением, отражением, глубиной резкости, освещением и камерой.
Compatible:
  • After Effects CC, CS6, CS5.5, CS5
Changes in 1.1.0:
  • Slide texture, depth composite functions are added
Release Name: Aescripts: Power Sphere v1.1.0
Release Date: Jan 23, 2015
Homepage
Requirements: Win64 / After Effects CC, CS6, CS5.5, CS5
Размер файла: 10.8Mb
Aescripts: Time Offset Animation v1.0 for After Effects
Time Offset Animation с легкостью создаёт анимации, основанные на времени смещения! Экономьте время создания сложных анимаций, позвольте этому скрипту сделать несколько вариантов одним нажатием кнопки!
Basic Composition Setup:
  • Create a simple animation on a single layer.
  • Create as many child layers as you want WITHOUT adding any animation.
  • Create an optional background layer.
  • Apply the Time Offset Animation tool.
  • Watch those animations go!!!
Compatible:
Release Name: Aescripts: Time Offset Animation v1.0
Release Date: Jun 9, 2014
Homepage
Requirements: After Effects CC, CS6, CS5.5, CS5
Размер файла: 25.9Mb
Aescripts: Project Cleaner v1.2 for After Effects
Project Cleaner - Скрипт для After Effects, предназначенный для основательной очистки ваших проектов от избыточных, неиспользуемых и пустых элементов.
Features:
  • Reduce redundant solids and redundant footages.
  • Remove unused solids and unused footages.
  • Remove all empty compositions and empty folders.
Displays a palette with tools that helps you to clean up nested projects or a messy project created by someone else.
You might need to nest projects in After Effects by adding several existing projects to your current project. Working in this way is useful for recovering from other projects, compositions or layers with their animations and their effects or for making changes without altering the original project. The problem is that the same footages or solids are found several times in the final project.
The function, ‘File > Consolidate All Footage’, looks for the extra instances in the project and combines them, also checking redundant solids taking into account the characteristics, including the name.
This script provides additional functions complementary to those already included in After Effects, as it allows checking all redundant footages and solids (regardless of the name or not). This allows a thorough cleaning of redundant footages and solids in the project.
This script also offers to simply remove all unused footages and solids, or remove empty compositions and empty folders. Note that empty folders may occur when you run the script for redundant items.
This script requires After Effects CS3 or higher. Runs on Mac and PC in the same way, tested on CS5, CS5.5, CS6 and CC.
Compatible:
  • After Effects CC, CS6, CS5.5, CS5, CS4, CS3
Changes in 1.2:
  • Fixed a problem of removing sources of Solids and Footages before being able to check layers in composition due to certain Layers types.
  • Fixed a problem of removing sources of Solids and Footages before checking all layers referring to this source in a composition.
Release Name: Aescripts: Project Cleaner v1.2
Release Date: Jan 2014
Homepage
Requirements: After Effects CC, CS6, CS5.5, CS5, CS4, CS3
Размер файла: 5.1Mb
Aescripts: ft-Brightness Check v2.1 (Win/Mac)
ft-Brightness Check - Инструмент для After Effects, Premiere и Photoshop, который позволяет узнать, какая часть вашего изображения слишком яркая или слишком темная, указывая плохие пиксели непосредственно на кадрах. Подобно тому, как zebra-stripping работает на цифровых камерах.
Compatible:
  • After Effects CS6, CS5.5, CS5, CS4, CS3
  • Premiere CS6, CS5.5, CS5, CS4
  • Photoshop CS5.5, CS5, CS4
Release Name: Aescripts: ft-Brightness Check v2.1
Homepage
Requirements: Win/Mac, After Effects, Premiere, Photoshop CS6, CS5.5, CS5, CS4
Размер файла: 6.4Mb
Aescripts: Trim N Collect v1.0 for After Effects
Trim N Collect - Скрипт для After Effects, который обрезает и перекодирует мультимедийные клипы, используемые в проекте, чтобы включить только используемые части, и создаёт новые пути к этим файлы. Это отличное решение, если вы хотите передать или заархивировать ваши проекты, сохранить дисковое пространство, время и деньги! Дополнительные опции дают вам полный контроль над размером, который вы хотите оставить, переработкой изображений и многоканальными EXR-последовательностями, а также над тем, как эти файлы собираются.
Features:
  • Automatic folder creation
  • Transcoding templates
  • Add handles
  • Automatically consolidate overlapping media
  • Consolidate gaps
  • Don’t transcode full range media
  • Export scripts (create a folder structure, establish project bit depth, etc.)
  • Image sequence processing:
    • Transcode image sequences will transcode the image sequences (with exception of exr files)
    • Transcode OpenEXR sequences will transcode the sequences of multichannel exr files using the template presets, depending on them having an alpha channel.
    • Customizable extensions for image sequences
  • Trimmed footage management
  • Collect options:
    • Collect C4D files (without dependencies)
    • Copy entire image sequences
    • Copy entire OpenEXR sequences
    • Do not collect files will not perform the collect operation at all, instead only trimming and transcoding the used parts of the footage to the destination folder
Compatible:
Release Name: Aescripts: Trim N Collect v1.0
Release Date: Jan 4, 2015
Homepage
Requirements: Win64 / After Effects CC 2014, CC, CS6
Размер файла: 10.4Mb
Aescripts: Randomizer v3.1 for After Effects
Randomizer - Скрипт для After Effects, который назначает случайные значения в пределах определенного диапазона к преобразованию свойств выбранных слоев.
Compatible:
Changes in 3.1.:
  • Fixed bug with 3D layers orientation, CC compatibility
Release Name: Aescripts: Randomizer v3.1
Release Date: March 2014
Homepage
Requirements: After Effects CC 2014, CC, CS6, CS5.5, CS5, CS4
Размер файла: 5.7Mb
Скачать
https://cloud.mail.ru/public/5e2227b0be73/Aescripts
Aescripts: versionUp v1.1 for After Effects
versionUp упрощает утомительную задачу обновления отснятого материала до последней версии. Скрипт упрощает переключение версий футажей до одного щелчка мыши. Выберите один или несколько фрагментов видеоматериала на панели проекта, щелкните кнопку со стрелкой вверх, и SmartRender будет обновлять кадры до следующей доступной версии. Нажмите кнопку со стрелкой вверх, удерживая клавишу переключения и versionUp будет пропускать футажи до последней доступной версии. Если вы когда-либо были разочарованы процессом замены футажей вручную, то versionUp именно для вас.
Features:
  • Click the up and down arrows to cycle through versions of your footage.
  • Shift + Click to skip straight to the newest or oldest versions available.
  • Option + Click to increment a letter following the version number.
  • Included non UI scripts can be assigned to ft-Toolbar buttons.
  • Custom keyboard shortcuts can be bound to perform all versionUp actions.
  • Automatically skips versions if they don’t exist.
  • Works with stills, movies, and image sequences.
  • It will even version up or down comp and folder names.
  • Updates all version numbers in the file path, not just in the file name.
  • Settings panel with options to customize the script to your liking.
Compatible:
Changes in 1.1:
NEW FEATURE: Option (Alt on PC) click to increment a letter following the version number. i.e. v001a becomes v001b.
NEW FEATURE: Includes standalone (non UI) scripts for use in ft-Toolbar or bind as custom keyboard shortcuts.
Release Name: Aescripts: versionUp v1.1
Release Date: Dec 7, 2014
Homepage
Размер файла: 8.9Mb
Aescripts: Recursive Scale Comp v1.08 for After Effects
Recursive Scale Comp - Этот скрипт для After Effects позволит вам масштабировать размеры композиции при сохранении оптимального качества изображения, при этом скрипт масштабирует не только основную композицию, но также рекурсивно любые вложенные композиции. Это максимизирует качество изображения композиции и позволяет легко масштабировать проекты для разных выходных разрешений.
Примечание: использование выражений в зависимости от трансформации или свойств камеры может быть необходимо преобразовать в ключевые кадры перед запуском скрипта.
Compatible:
Changes in 1.08:
  • Fixed scaling bug with comps that have keyframes
Release Name: Aescripts: Recursive Scale Comp v1.08
Release Date: Mar 2013
Homepage
Requirements: After Effects CS6, CS5.5, CS5, CS4, CS3
Размер файла: 3.7Mb
Aescripts: ft-Technicolor v2.1
ft-Technicolor - Фильтр для After Effects, Premiere и Photoshop, который имитирует грейдинг фильма Мартина Скорсезе “Авиатор”, иначе называемый двухполосной и трёхполосной системой цветного кино.
Compatible:
Release Name: Aescripts: ft-Technicolor v2.1
Homepage
Размер файла: 206Kb
Aescripts: SplitImage v2.2 for After Effects
SplitImage - Этот скрипт для After Effects позволяет разделить выбранный элемент проекта на прямоугольные куски.
Compatible:
Release Name: Aescripts: SplitImage v2.2
Homepage
Размер файла: 1.4Mb
Aescripts: Real Glow v1.0.0 for After Effects (Win64)
Real Glow - Генератор реалистичного свечения для Adobe After Effects, разработанный на базе доказанных отраслевых методов и алгоритмов, работает на основе реальных оптических свойств, вместо простого линейного размытия используемого в свечении, встроенном в After Effects или другие подобные плагины. Идеально подходит для создания реалистичных светящихся световых явлений, научно-фантастических энергетических эффектов, или анимационной графики. Real Glow имеет простой и интуитивно понятный интерфейс для создания потрясающих и реалистичных визуальных эффектов свечения.
Compatible:
Changes in v1.0.0:
  • Initial release
Release Name: Aescripts: Real Glow v1.0.0
Release Date: Feb 27, 2015
Homepage
Requirements: Win64 / After Effects CC 2014, CC, CS6, CS5.5, CS5
Размер файла: 23.7Mb
Урок от производителя Real Glow v1.0.0 for After Effects (Win64) “aescripts”
Aescripts: Un-PreCompose v1.04 for After Effects
Un-Precompose - Плагин для After Effects, который позволяет выбрать вложенную композицию, извлечь и перенести все её слои в родительскую композицию при сохранении каждого слоя эффектов и других свойств, при этом у вас есть различные варианты для поддержания или удаление свойства из этой композиции.
Release Name: Aescripts: Un-PreCompose v1.04
Release Date: Apr 29, 2011
Homepage
Requirements: After Effects CC 2014, CC, CS6, CS5.5, CS5, CS4, CS3
Размер файла: 8.1Mb
