Portable Mini Jibs/Cranes
1.7m Mini Video Camera Crane Jib Arm Portable Pan Tilt Crane Jib
US $274.98
Approximately EUR 199.51
4.2 Foot Mini Video Camera Crane Jib Arm Portable Pan Tilt Crane Jib
US $148.94
Approximately EUR 108.06
4 Foot Small Camera Crane Jib with bearings, for DSLR’s Film Video, “L” bracket
US $124.98
Approximately EUR 90.68
ИМХО, плохо то что площадка для камеры посажена НЕ по оси , а с боку. На таких кранах трудно установить “горизонт” поскольку камера “выворачивает” стрелу и горизон заваливается …но за такую цену можно и пренебречь
Portable DSLR Mini Jib Crane Video Camera Jib Video Jib Arm with 2 QR Plate
US $179.99
Approximately EUR 130.59
  • очень компактная версия
  • цена
  • наклон камеры НЕ регулируется
  • стрелы “круглые” - прямоугольные стрелы более жесткие
Коллеги, давайте соберем в одной теме как можно больше моделей по принципу
компактно - дешево - функционально
Trapezist MK2 Portable Traveling Mini Jib
Trapezist mk2 is an upgraded version from the previous model in 2013 with additional functions and features.
Trapezist is a portable mini jib that allows photographer to create dynamic footage with multi-angle camera movements. Simple set up and operation that only require one person involve. With a maximum extension to 210 centimeter, this portable mini jib can also be as small as just 75 centimeter long when traveling. Trapezist connects to camera with a quick release plate that could attach directly via ¼ or 3/8 thread screw. With an adaptor, a 75mm or 100mm bowl fluid head can attach to Transpotta in just a minute.
Specification
Multi Mounting System (MMS) -Available to switch between flat base (3/8" screw thread) and 75mm bowl head adaptor. MMS provides you the maximum flexibility in the choice of supporting head.
Quick Release System (QRS)– A simple slide and lock system between camera and Trapezist. When time is cost, this little device gives a great effort of saving time.
Main features of Trapezist MK 2
from USD$299
https://vimeo.com/44300863
почти гениально… правда непонятно куда там противовес цеплять:
US$ 161.91 (1м)
US$ 201.62 (1.2м)
2 in 1 40 inch/ 1.0 Meter Mini Telescopic Rock Jib Arm Camera Crane
Думаю , если доработать какоелибо ребро жесткости можно будет испльзовать слайдет с одной треногой. С двумя , всетаки немобильно и морока с выравниванием горизонта
Очень интерессный девайс !
понравилась мобильность и возможность поворота. Правда второе достоинство спорно, поскольку в положении для горизонтального вращения головой нет возможности а не вертикального вращения , а не удержания горизонта при подьеме спуске камеры
Price: 359.11 Euro
Внимание на 2:00 , видео раньше второй минуты можно не смотреть.
у головы данного крана одна ось вращения и поэтому в положении для горизонтального вращения головой нет возможности а не вертикального вращения , а не удержания горизонта при подьеме-спуске камеры
( если доработать голову и сделать две оси вращения - былоб очень универсально…)
