Sony NEX-FS700
Спецификация
Image Sensor 4K Exmor Super 35 CMOS Image Sensor (11.6MP)
Effective Pixels HD: 8,400,000 pixels
Photo: 7,100,000 pixels
Aspect Ratio HD: 16:9
Photo: 16:9 or 3:2
Resolution Not specified by manufacturer
Sensitivity ISO 500 (0 dB) - ISO 16,000 (30 dB)
ND Filter Switching Mechanism Clear
1/4 = ND.6 (2 stops)
1/16 = ND1.2 (4 stops)
1/64 = ND1.8 (6 stops)
Color Temperature Auto, One Push AB, Indoor (3200K)
Outdoor (5800K ± 7 positions)
Manual WB Temperature (2300 - 15000K, 100K step)
Super Slow Motion 120 fps
240 fps
480 fps
960 fps
Signal System 50/60Hz (NTSC/PAL)
LCD Monitor 3.5" (8.9 cm)
Screen Resolution Approx. 921,000 dots (1920 x 480)
Viewfinder Supplied VF tube for LCD
Shutter Speed Not specified by manufacturer
White Balance Not specified by manufacturer
Recording Media Flash Memory Unit (HXR-FMU128)
MS PRO Duo (Mark2 only)
MS PRO-HG Duo
SD/SDHC/SDXC (class 4 and higher)
Recording Formats PS max 28 Mbps, 1920 x 1080/60p, 50p (16:9)
FX max 24 Mbps, 1920 x 1080/60i, 50i, 30p, 25p, 24p (16:9)
1280 x 720/60p, 50p (16:9)
FH approx. 17 Mbps (ave), 1920 x 1080/60i, 50i, 30p, 25p, 24p (16:9)
HQ approx. 9 Mbps (ave), 1440 x 1080/60i, 50i (16:9)
LP approx. 5 Mbps (ave), 1440 x 1080/60i, 50i (16:9)
HQ approx. 9 Mbps (ave), 720 x 480/60i, 720 x 576/50i (16:9, 4:3)
Video Recording Format MPEG-4 AVC/H.264 AVCHD Ver.2.0 (HD video)
MPEG-2 PS (SD video)
Audio Recording Format Linear PCM 2ch (48 kHz, 16-bit) (in HD)
Dolby Digital 2ch (48 kHz, 16-bit)
Recording/Playback Time Not specified by manufacturer
Input/Output Connectors 3G HD-SDI Output: BNC connecter x 1
HDMI Output: HDMI connecter (type A) x 1
Component Output: mini D terminal x 1
Video Output: RCA Pin x 1
Audio Output: RCA Pin x 2
Headphone Jack: stereo mini jack (3.5 mm) x 1
USB Port: mini-AB x 1
Audio Input 1 / Input 2: XLR 3-pin (female) x 2 (LINE/MIC/MIC +48V selectable)
Remote: stereo mini-mini jack (2.5 mm) x 1
Power Supply DC 7.2 V (battery pack)
DC 7.6 V (AC-DC adapter)
Power Consumption 9.6W (60i)
8.8W (50i)
Operating Temperature 32 to 104°F (0 to 40°C)
Storage Temperature -4 to 140°F (-20 to 60°C)
Dimensions (WxHxD) 5.7 x 7.0 x 9.3" (145 x 178.5 x 235.5 mm) including protrusions
Weight Body Only: 3.7 lb (1680 g)
Fully Loaded: 6.75 lb (3060 g)
Компания Sony представила NEX-FS700 — новейшую модель в линейке профессиональных видеокамер. В камере используется датчик изображения формата Super 35. Другими словами, размер кадра равен 24,89 х 18,66 мм, что несколько больше размеров 35-миллиметровго кадра киноплёнки, которые, как известно, равны 21,95 х 16 мм. NEX-FS700 предназначена для съёмки видео высокой чёткости. Камера имеет возможность вести высокоскоростную съёмку — до 960 к/с. Видеокамера имеет встроенные фильтры нейтральной плотности и выход 3G HD-SDI для подключения внешнего рекордера. Этот выход позволяет передавать по одному коаксиальному кабелю сигнал видео высокой четкости с прогрессивной разверткой, характеризующийся скоростью потока до 2,970 Гбит/с.
По словам производителя, камера NEX-FS700 «открывает дверь в новый мир творческой съёмки», поскольку подходит для разных видов съемки — от музыкальных видеоклипов и документалистики до художественного кино и спортивных репортажей.Видеокамера снимает видео высокой четкости со скоростью 120 и 240 к/с, а в режиме серийной фотосъёмки доступны скорости 8 и 16 к/с. Высокая чувствительность матрицы и низкий уровень шума позволяет снимать качественное видео в режиме сверхскоростной киносъёмки (Super Slow Motion) без дополнительного оборудования. Понизив разрешение, можно увеличить частоту кадров до 480-960 к/с. Камера NEX-FS700 оборудована новым датчиком изображения CMOS Exmor (11,6 Мп). Данная матрица оптимизирована для сьёмки движущихся объектов с высокой чувствительностью, низким уровнем шума и минимальным сглаживанием.
Устройство оборудовано байонетом E-mount. Помимо объективов с байонетом E-mount, к NEX-FS700 можно присоединить практически любые объективы для зеркальных и цифровых зеркальных фотоаппаратов, используя адаптеры. Также, владельцы камер серии FS могут использовать объективы от своих камер на новой NEX-FS700. Новинка, помимо видеосъёмки, позволяет делать высококачественные фото. NEX-FS700 включает в себя технологию распознавания лиц и автофокус. Видеокамера переключается между режимами 50 и 60 Гц, что позволяет не ограничиваться одним из стандартов PAL или NTSC.
Камера NEX-FS700 оборудована портами 3G HD-SDI и HDMI, которые позволяют передавать видео формата Full HD 50p и 60р, в дополнение к стандартным форматам HD 60i, 24p, 25p или 30p со звуком и встроенным таймкодом. Порт 3G HD-SDI позволяет передавать сигналы с прогрессивной развёрткой и кадровой частотой 23,98 Гц, 25 Гц и 29,97 Гц. Пользователи камеры могут сохранять до 99 профилей настроек видеокамеры. Эти профили хранятся на карте памяти и могут быть скопированы на другую такую же камеру. NEX-FS700 имеет слоты для карт памяти формата MS и SD, а также поддерживает рекордер Sony HXR-FMU128, объём которого составляет 128 ГБ.
К камере при помощи пары винтов и крепления холодный башмак может быть присоединена верхняя ручка с розеткой подключения. На ручке продублирован доступ к нескольким основным функциям.
Компания Sony планирует в скором времени выпустить прошивку, которая позволит камере NEX-FS700 выводить видеопоток 4К через порт 3G HD-SDI на дополнительный рекордер Sony 4K.
Обновление прошивки для камеры FS700 и расширение её функций до 4К:
Software : NEX-FS700E/FS700EK V2.0
http://www.sony.ru/pro/support/software/SET_BPE-SS-1030/1
NEW FEATURE
Zoom locker key on the NEX-FS700E can control a power zoom lens.
The following lenses have optical power zoom function (as of Feb 2013):
  • SEL-P18200
  • SEL-P1650
NOTE
  • Though the zoom locker key on the NEX-FS700E will be activated, the NEX-FS700E will not have the Digital Zoom function.
  • When the SEL-P1650 is used on the NEX-FS700E, distortion, aberration and/or light fall off at the image periphery may occur at wide-angle focal lengths.
Software : NEX-FS700E/FS700EK V3.0:
http://www.sony.ru/pro/support/software/SET_BPE-SS-1030/10
NEW FEATURE
1.) RAW shooting mode
  • Output RAW data to SDI interface.
  • Resolutions and framerate: 4K (4096x2160) and 2K (2048x1080) at 50p, 25p, 23.98p, 59.94p and 29.97p
  • Super Slow Motion: 4K at 120 and 100 fps (approx. 4 sec) and 2K at 240, 200, 120 and 100 fps (continuous, depending on AXSM memory capacity)
    2.) Addition of S-Log2 (1300% Dynamic Range) and 709 (800%) gamma curves.
    3.) Rec trigger output on SDI and HDMI, for compatible control with external recorder.
    4.) Secure acces mode of Professional PX series Memory Stick.
    5.) Power zoom lens control (available also on V2.00).
COMPATIBILITY INFORMATION:
In order to process NEX-FS700 RAW data recorded by AXS-R5, update of the following software is needed, depending on user’s equipment:
  • AXS-R5: V1.2
  • RAW Viewer: V1.1
  • RAW Plug-in for Avid: V1.2
  • RAW Plug-in for Adobe: V1.2
UPGRADE PROCEDURE:
This upgrade requires a hardware modifcation which can only be performed by Sony engineer. Please contact PrimeSupport or the SONYSOS Helpdesk for details.
Перевод пункта выше
Процедура обновления:
Данное обновление требуется аппаратной модификации которую могут быть выполнены только инженером Sony. Пожалуйста, свяжитесь с PrimeSupport или SONYSOS
NOTE:
Users that purchase an HXR-IFR5 will be given a voucher so that the upgrade is free of charge (valid until the 31st December 2013).
Для записи RAW 4к необходим рекордер
fs700: апгрейд до 4К
https://vimeo.com/75526189
4k RAW
https://vimeo.com/83168895
https://vimeo.com/79517736
https://vimeo.com/73974395
