ChangeLog
v2015.build.65+Recorder (May 31 2015)
[ADD] Support to Play and Encode into HEVC/H.265 UHD 4K mode
[ADD] Speed optimization to encode into the MP4 Output Container
[ADD] Speed optimization to encode into the FLV Output Container
[Fix] Various critical bugs
v2015.build.64+Recorder (February 13 2015)
[ADD] General updates to most encoding engines to fully support latest Win8.1 configuration
[ADD] Support for input files with g729 Audio Codec
[ADD] Optimization to encode into the WMV Output Container
[ADD] Optimization to encode into the TS (Transp) / M2TS (BluRay) Output Container
[Fix] bug causing black image when HEVC/H.265 encoding file is larger than 3 hours
v2014.build.63+Recorder (November 27 2014)
[Fix] bug on some WinXP machines not allowing HEVC/H.265 encoding
[Fix] bug on some WinXP machines not allowing VP9 encoding
v2014.build.62+Recorder (September 21 2014)
[ADD] optimization to process the *.ass *.psb *.smi *.srt *.ssa Subtitles formats
[Fix] bug when encoding an *.IFO input file
[Fix] HEVC/H.265 encoding bug when input is a sequance of images
[Fix] VP9 encoding bug when input is a sequance of images
v2014.build.61+Recorder (June 19 2014)
[ADD] HEVC/H.265 Video Codec full encode/decode/play support to ASF and WMV containers
[ADD] KOD86MIX engine optimization to HEVC/H.265 and VP9 encoding to speed it up and eliminate errors
[ADD] Option to Apply Subtitles in *.ass *.psb *.smi *.srt *.ssa formats
[ADD] Option to Apply Additional Video Layer using additional Image or Video files to be layered over the existing Video Stream
[ADD] Detect All Streams support during Split, Mux & DeMux Output Process
[ADD] Detect All Streams support EVEN during Audio Stream Copy
[Fix] Detect All Streams bug not detecting some files
[Fix] Various bugs and apply global optimization for improved performance on Win8|8.1 and consequently on Win7 and Vista
v2014.build.60+Recorder (Feb 18 2014)
[ADD] Global quality/speed optimization to HEVC/H.265 and VP9 encoding
[ADD] HEVC/H.265 Video Codec full encode/decode/play support to TS (Transp) / M2TS (BluRay) containers
[ADD] To TS (Transp) / M2TS (BluRay) & Sony - PS3 (BluRay) the following video bitrate 960 - 1440 - 1920 kbps
[ADD] To VP9 Video codec the 1440:1080 Video Scale Size preset
[ADD] DirectShow LAV Filters for encoding in DirectShow mode when the DirectShow Decode switch is checked
[ADD] ‘C’ tiny button in the DirectShow Decode panel for easy DirectShow LAV Filters Configuration
[ADD] HEVC/H.265 support to the DeMux Extract Streams funtion in Files Output Process mode
[Fix] The HEVC/H.265 1440:1080 and 1920:1080 encoding error bug
[Fix] The AAC <Audio Only> encoding error when selecting HE-AAC and HE-AACv2
v2013.build.59+Recorder (Dec 18 2013)
[ADD] Additional VideoScaleSize settings to the HEVC/H.265 Video Codec inside MKV, MOV, MP4 containers
[ADD] Increased encoding speed and Higher quality to the HEVC/H.265 and VP9 Video Codecs, however, a CPU
not older than 3 years is still required to correctly handle the HEVC/H.265 Video Codec encoding process
[ADD] Or complement the following Output Containers AVI | MKV | MOV | MP4 | TS/M2TS | Sony - PS3 (BluRay) | AAC
with the widest selection of AAC Audio Codec: AAC LC | AAC Main | AAC LTP | HE-AAC | HE-AACv2
[ADD] or complement the following Output Containers M4A | Android - Phone/Tablet (MP4) | Apple - iPad/iPod/iPhone (MP4) |
Blackberry - (MP4) | Microsoft - Xbox (MP4) | Microsoft - Zune (MP4) with these 2 widely used AAC Audio Codec: AAC LC | HE-AACv2
[ADD] To MENU a new option to enable/disable those pop alert messages [Enable Pop-Up Information Alert Messages]
[ADD] Brightness and Contrast adjustment settings directly on the left/right side of the Player Window
[Fix] A serious FPS/speed issue with the TS|M2TS Output Container
v2013.build.58+Recorder (Nov 13 2013)
[ADD] HEVC/H.265 Video Codec full support to decode/play any file or encode it inside MKV, MOV, MP4 containers
[ADD] VP9 Video Codec full support to decode/play any file or encode it inside MKV and WebM containers
[ADD] [Adobe Flash Video Compliant] profile full support to decode/play any file or encode it inside FLV container
[ADD] Higher quality and speed to the ‘DeMux Output Process’ using the new KOD86MIX engine
[Fix] the Dirac Video Codec encoding with AVI, MKV, MOV, TS output containers
v2013.build.57+Recorder (July 13 2013)
[Fix] A major update issue on the KOD86MIX engine to speed up all encoding tasks
v2013.build.56+Recorder (July 7 2013)
[ADD] A newly implemented KOD86MIX engine speeding up the entire encoding process
[ADD] Support to encode, play and render ‘APE, AC3, DTS, mp3, Speex’ Audio Codecs when the following Video Codecs
are selected Dirac, JPEG2000, CamStudio, Lagarith, VP4, VP6, VP61, VP7 in the MOV Output Container
[ADD] Several newly implemented supported formats to the ‘Join Format-Identical Files’ function in the Output Process
[ADD] New options to the ‘Output File Saving Manager’
[ADD] Global enhancement to the ‘Multimedia Analysis Box’
[ADD] Enhancement to the Video/Audio Capture Recording engine from WebCam, Tuner, DeskTopCapture, Sound Card, Microphone etc…
+Recorder.2013.55 (Mar 7 2013)
[ADD] Video/Audio Capture Recording feature from WebCam, Tuner, DeskTopCapture, Sound Card, Microphone etc…
[ADD] UNICODE Input/source files support to Play or Encode files like Arabic, Greek, Hebrew, Russian, Thai etc…
[ADD] Support to encode, play and render ‘ASAO’ Audio Codec in FLV Output Container
[ADD] Support to encode, play and render ‘Apple ProRes (iCodec Pro)’ Video Codec in MOV Output Container with 8 different profiles
[ADD] Additional supported formats to the ‘Join Format-Identical Files’ function in the Output Process
[ADD] Additional supported support to the ‘Split Into Smaller Files’ function in the Output Process
[Fix] Default OUTPUT Folder to ‘…\My documents\eRightSoft\OutPut’
[Fix] Bug with rendered SWF files where AUDIO wasn’t correctly played on web browser in stream mode
[Fix] Very critical bug
v2012.build.54 (Nov 18 2012)
[ADD] Windows® 8 compatibility
[ADD] New encoding engine
v2012.build.53 (Sep 13 2012)
[ADD] Great overall speed and quality enhancement when encoding and using the Hi444PP Output Video Codec
[ADD] Great overall speed and quality enhancement when encoding into RM Output Container
[ADD] Great overall speed and quality enhancement when encoding into TS/M2TS Output Container
[ADD] Great overall speed and quality enhancement when encoding into WTV Output Container
[ADD] Great overall speed and quality enhancement when encoding into Android - Phone/Tablet (MP4) Output Container
[ADD] Great overall speed and quality enhancement when encoding into Apple - iPad/iPod/iPhone (MP4) Output Container
[ADD] Great overall speed and quality enhancement when encoding into Blackberry - (MP4) Output Container
v2012.build.52 (July 7 2012)
[ADD] DTS (Audio Only) Output Container
[ADD] Support to encode, play and render DTS (Digital Theater Systems) Audio Codec in MKV Output Container
[ADD] Support to encode, play and render DTS (Digital Theater Systems) Audio Codec in MOV Output Container (Not with Video Codecs Playable with QuickTime)
[ADD] Support to encode, play and render mp3 Audio Codec in TS/M2TS Output Container
[ADD] New Profile Hi444PP when encoding using the H.264/AVC Video Codec
[ADD] 2 Profile selection when encoding using the MPEG-II Video Codec inside GXF, MPG, TS/M2TS, DVD, SVCD Containers
[ADD] Speed enhacement when encoding into FLV/SWF Output Container
[ADD] Speed enhacement when encoding into DV Output Container
[ADD] Speed enhacement when encoding into TS/M2TS Output Container
[ADD] Speed enhacement when encoding into WebM Output Container
v2012.build.51 (April 7 2012)
[ADD] 3GA format to the ‘Add Multimedia File(s)’ detection
[ADD] F4V format to the ‘Add Multimedia File(s)’ detection
[ADD] IFO format to the ‘Add Multimedia File(s)’ detection
[ADD] MXG format to the ‘Add Multimedia File(s)’ detection
[ADD] ‘Current OS’ Skin profile (no skin)
[Fix] encoding error with RM and RA Output Container
[Fix] VideoScaleSize/fps selection interlock with PAL and NTSC
[Fix] Access violation error at startup
v2012.build.50 (February 21st 2012)
[ADD] Android MP4 Output Container
[ADD] Blackberry MP4 Output Container
[ADD] Xbox MP4 Output Container
[ADD] GXF Output Container using Video Codecs DV (with profiles), M-JPEG, MPEG-I, MPEG-II
[ADD] WTV Output Container
[ADD] RM & RA Output Containers using rv8, rv9, rv9 Video Codecs and AAC LC, AAC HE, Atrac3, Real Lossless and Cook Audio Codecs
[ADD] H.264 Video Codec to the MPG Output Container
[ADD] Dirac Video Codec to the TS|M2TS Output Container
[ADD] DTS (Digital Theater Systems) Audio Codec to the TS|M2TS Output Container
[ADD] Speex Audio Codec to the ASF, MKV, MOV, WMV Output Containers
[ADD] an option to embed MPlayer inside a window with various options
[ADD] an option to Drag & Drop a Folder to open its content recursively
[ADD] an option to Drag & Drop a playlist and open its content
[ADD] an option to Drag & Drop any file or to limit to ONLY supported file formats
[ADD] a very long list of newly implemented features
v2011.build.49 (July 1st 2011)
[ADD] Profile and Level selection to the MPEG-4 and Divx Video Codec in AVI container with FFmpeg
[ADD] DV, DVCPRO25 and DVCPRO50 Profile selection when encoding ‘DV Digital Video’ with DV or MOV container
[ADD] Support to encode, play and render VP6 and VP61 Video Codec in SWF container
[ADD] Support to encode, play and render Dirac Video Codec in AVI container with FFmpeg
[ADD] Support to encode, play and render Dirac Video Codec in MKV container
[ADD] Support to encode, play and render Dirac Video Codec in MOV container
[ADD] Support to encode, play and render Raw UnCompressed and QuickTime Animation Video Codec in MOV container
[ADD] Support to encode, play and render M_JPEG and MS-mpeg4-v1 Video Codec in MKV container
[ADD] Support to encode, play and render Screen Video Lossless Codec in AVI container with FFmpeg
[ADD] Support to encode, play and render Screen Video Lossless Codec in ASF/WMV container
[ADD] Support to encode, play and render Screen Video Lossless Codec in FLV container
[ADD] Support to encode, play and render Screen Video Lossless Codec in MKV container
[ADD] Support to encode, play and render Screen Video Lossless Codec in MOV container
[ADD] Support to encode, play and render A-Law and µ-Law Audio Codec in MKV container
[ADD] Support to encode, play and render A-Law and µ-Law Audio Codec in MOV container
[ADD] Support to encode, play and render A-Law and µ-Law Audio Codec in WAV container
[ADD] Support to encode, play and render 6 Channels with all WAV Audio Codec
v2011.build.48 (Apr 23 2011)
[ADD] DVCPRO25 and DVCPRO50 format to the ‘DV Digital Video’ Output Container
[ADD] new settings to render sequentially numbered SGI and TGA files with the ‘Sequence Of Images’ profile
[ADD] support for sequentially numbered SGI, TGA input files
[FIX] Video Bitrate for ASF/WMV by lifting limitation from 6000 to 9792
[FIX] Video Bitrate for AVI,MKV,MOV,MP4,MPG,OGG by lifting limitation from 9600 to 9792
[FIX] bug when rendering DVD in AutoMode with .ifo & .bup files
v2011.build.47 (Mar 12 2011)
[ADD] MXF format to the ‘Add Multimedia File(s)’ detection
[ADD] MTS format to the ‘Add Multimedia File(s)’ detection
[ADD] Whole range of FPS when the ‘DV Digital Video’ is selected
[FIX] BFrames support when encoding with MEncoder
[FIX] VOB format to correctly render 16:9 files with .ifo & .bup files
v2011.build.46 (Feb 12 2011)
[FIX] WebM output container optimization
[FIX] WMV output container optimization
[FIX] iPad profile ‘Apple - iPad/iPod/iPhone (MP4)’ optimization
[FIX] VP7 Video Codec optimization
v2011.build.45 (Feb 10 2011)
[ADD] sequence of Images profile to render sequentially numbered BMP files
[FIX] VP8 bug rendering upside-down video at 25 FPS
v2011.build.44 (Jan 21 2011)
[ADD] New function in the Output Process to Split Files into smaller parts
[ADD] Support to encode and render MTV Mp.man Video files
[ADD] Support to encode, play and render the WEBM container
[ADD] Support to encode, play and render the M4A Audio container
[ADD] Support to encode, play and render VP61 Video Codec in FLV container
[ADD] Support to encode, play and render huffYUV (Lossless) Video Codec in MOV container
[ADD] Support to encode, play and render VP40, VP60, VP61, VP70, VP8, JPEG2000, Lagarith (lossless), Cinepak in ASF & WMV containers
[ADD] Support to encode, play and render .wv in MKV container
[ADD] Support to encode, play and render .ape, AC3, mp3 in MOV container
[ADD] Support to encode, play and render the VP8 Video Codec in AVI, MKV, and MOV containers
[ADD] Support to encode, play and render AAC & AC3 in ASF & WMV containers
[ADD] Support to encode, play and render ALAC (Apple Lossless) in the Apple - iPad/iPod/iPhone (MP4) profile
[ADD] Support to encode and play the .vqf Audio Codec
[FIX] The Join files function in the Output Process to support 3gp, 3g2, m4v, mov, mp4
v2010.build.42 (Nov 7, 2010)
[ADD] Make SUPER© 100% Windows® Server 2008 Compatible
[ADD] A new design to speed up the rendering process
[ADD] Enhancement code to optimize the H.264/AVC Ouput Video Codec
[ADD] Enhancement code to speed up the conversion of input files like MPG, VOB, DV, WTV etc…
[FIX] Code to render VP4, VP6, VP7… with the selected VideoScaleSize instead of keeping the input file’s VideoScaleSize
v2010.build.41 (Oct 31, 2010)
[ADD] A key to the MENU to select the ‘Older Validation Procedure’ as the new one is causing SUPER© to shut down on few PCs when encoding
[FIX] Code modification related to the Vorbis Audio Codec causing encoding errors
v2010.build.39 (Oct 24, 2010)
[ADD] Feature to adapt SUPER© to various NoteBook small screen resolution
[ADD] Support to encode, play and render VP60 Video Codec in FLV container
[ADD] Support to encode, play and render VP40, VP60, VP61, VP70, JPEG2000, Lagarith (lossless), Cinepak in AVI, MKV and MOV containers
[ADD] Support to encode, play and render ADPCM IMA, WAV-(pcm 16 little-endian) and WAV-(pcm U8) in MKV container
[ADD] Support to encode, play and render A-Law Audio Codec in WAV container
[FIX] 20% Faster H.264 encoding
[FIX] Application startup speed enhancing
[FIX] Several bug fixes and coding enhancements…
v2010.build.38 (May 2, 2010)
[ADD] Make SUPER© 100% Windows® 7 Compatible
[ADD] Option to create .ifo and .bup files when rendering DVD VOB files
[ADD] Support to encode, play and render Audio SHN (shorten)
[ADD] Support to encode and render Audio TAK (T)om’s lossless (A)udio (K)ompressor
[ADD] Support of input WTV Windows® 7 Media Center files
[ADD] Support of input MP4 files from HDTV handycam using the JTV profile
[FIX] The DeMux Output Process coding to improve demuxing speed
v2010.build.37 (Jan 2, 2010)
[ADD] the TS and M2TS containers to the Muxer Output Process function
[ADD] Support to encode, play and render FLAC(Free Lossless Audio Codec) container
[ADD] Support to encode, play and render DV (Digital Video) container
[ADD] 720:480 VideoScaleSize NTSC 29.97fps to the ‘DV Digital Video’ Video Codec
[ADD] 640:360 VideoScaleSize to the ‘Sony - PS3 (MP4)’ profile
[ADD] successTONE or errorTONE to play when process is done
[ADD] Improved Multithread support of multiple CPU cores
v2009.build.36 (June 10, 2009)
[ADD] New functions as Output Process to Join, Mux and Demux input files
[ADD] Menu [M] button visible with the LongHorn skin, same functionality as a RightClick
[ADD] Support to encode, play and render FLV files using the H.264 video codec
[ADD] Support to encode SMV sigmaTel Motion Video files
[ADD] Support to encode AMV files compatible with Actions ATJ2093H and Sunplus SPMP3052
[ADD] Support to encode, play and render APE(Monkey’s Audio Lossless) file format
[ADD] Support to encode, play and render TTA(True Audio Lossless) file format
[ADD] Support to encode, play and render WV(WavPack Audio Lossless) file format
[ADD] Support to encode, play and render ALAC(Apple Losless) inside the MOV container
[ADD] Multithread support with auto-detection of multiple CPU cores
[ADD] Thread priority selection through the MENU for all internal encoders
[ADD] Several new encoding improvements and enhancements…
v2009.build.35 (Jan 5, 2009)
[ADD] Support to encode, play and render WMV9 and WVC1 with the ASF, AVI, MKV, WMV and Zune containers
[ADD] Support to encode, play and render WMA3 with the ASF, AVI, MKV, WMV and Zune containers
[ADD] Bframe support when using the WMV9/WVC1 video codecs
[ADD] OGG (Audio Only) Output Container, rename the old OGG(Video, Audio) to OGM(Video, Audio)
[ADD] Support to encode, play and render vorbis (very high quality) with the OGG (Audio Only) container
[ADD] Support to encode, play and render FLAC (lossless) with the MKV, OGM, OGG containers
[ADD] H.264 Profile/Level/Ref CheckBox to tweak 3GP/3G2, iPod, Zune, PSP, PS3, TS and M2TS containers
[FIX] a long list of small bug fixes and coding enhancements…
v2008.build.33 (Sep 2, 2008)
[FIX] a disconnected Internet Media Streaming for http:// mms:// rtsp:// protocols
[FIX] extend the mp3 Audio Bitrate in flv/swf profile when the 44100 Hz sampling rate is selected
v2008.build.32 (Jul 8, 2008)
[ADD] Support to encode, play and render MKV in various video and audio codecs
[ADD] Support to encode, play and render HD TS (Transport Stream) and M2TS (BluRay) files
[ADD] Support to encode, play and render AAC 5.1 Channels
[ADD] Support to encode and play Tivo TMF and TY+ input files
[ADD] Support to encode and play DRV-MS input files
[ADD] Improved iPod/iPhone/iTunes support with various VideoScaleSize
[ADD] Zune (mp4) output format support
[ADD] PS3 (BluRay) output format support
[ADD] a long list of video and audio enhancements…
v2008.build.30 (Mar 22, 2008)
[FIX] SUPER© compatibility with Windows® Vista SP1
[FIX] GetTickCount, list out of bounds and other sporadic errors
[ADD] streamable H.264 rendered file in MP4 and MOV containers
[ADD] option to render lower case file extension to be Linux compatible
[ADD] 480:320 VideoScaleSize to the Apple - iPod profile, specific for iPhone
[ADD] better support and faster encoding of DPG files even on Win 9x/Me
[ADD] better support for encoding in ASF, WMV and Zune formats
v2008.build.25 (Feb 5, 2008)
[FIX] make SUPER© 100% Windows® Vista Compatible
[FIX] various encoding enhancements for Windows® XP users
v2008.build.24 (Jan 18, 2008)
[ADD] sequence Of Images profile to render sequentially numbered JPG, PGM, PPM, PNG files
[ADD] support for sequentially numbered JPG, PGM, PPM, PNG input files
[ADD] the adpcm Audio Codec to the FLV output container profile
[ADD] support to play SWF files even when encoded with the adpcm Audio Codec
[ADD] support to play AMV files
[ADD] support for AMV input files
[ADD] a Warning test for the minimum requirements at program startup
[ADD] option to set GOP to Auto/Manual
[ADD] option to set GOP to Open/Closed
[ADD] option to set B_Frames when using MPEG-I, MPEG-II, MPEG-4, H.264 and Xvid video codecs
[ADD] option to set the Interlace mode when using the MPEG-II and MPEG-4 video codecs
v2007.build.23 (July 4, 2007)
[ADD] Nintendo DS profile to output .dpg files
[ADD] ADPCM IMA & MS to avi, avi (for Pocket PC), asf, wmv, wav
[ADD] extended VideoScaleSize and FPS selection values
[ADD] extended VideoScaleSize with the Gif profile
[ADD] custom VideoScaleSize and FPS selection
[ADD] option to 'Save Every Output File In The Same Folder Of Its Respective Source File
[ADD] a frame Muxer when using the File Joiner
[ADD] a Custom Meta Tagger when rendering .flv files
[FIX] many internal routines where optimized for stability and speed using pure assembly language
v2007.build.22 (Mar 14, 2007)
[ADD] multiple files drag & drop
[ADD] ‘Direct Stream Copy’ feature
[ADD] H.264/AVC video codec to the 3gp/3g2 profile
[ADD] AAC audio codec used/muxed with AVI files
[ADD] 11025, 12000 KHz to mp3 and 16000, 32000 KHz to mp2/mp3 audio codec
[ADD] 1280:544 widescreen videoscale to PS3 profile
[ADD] 480:272 widescreen videoscale to PSP profile
[ADD] 320:180 widescreen videoscale to Zune profile
[ADD] 128:96 and 170:144 low resolution videoscale to MP4/MOV[H.264|MPEG-4|DivX|XviD]
[ADD] option to select spaces/underScores in output file name
[ADD] option prompting renaming of VOB file
[ADD] play Images (bmp, dib, fax, jpg, png, rle, tif, wmf) through Win2K/XP Microsoft® resources
[FIX] enhanced support for HDTV .TS & .M2T files
[FIX] lot of other enhancement and bugfixes
v2007.build.21 (Jan 4, 2007)
[ADD] Apple iPod 5.5G profile with H.264/AVC support
[ADD] Microsoft ZUNE profile with WMV7/8 + WMA support
[ADD] SONY PS3 profile with high resolution H.264/AVC support
[ADD] SMAF (.mmf) RingTone 'Synthetic music Mobile Application Format
[ADD] Support for rendering WMA Audio files
[ADD] DV Digital Video codec support to AVI and MOV containers
[ADD] Support to play/re-encode 3G2 files having Vorbis audio
[ADD] Support to play/re-encode flv4 with or without DirectShow
[ADD] Support to play/re-encode NSV files
[ADD] 5.99 - 6.25 - 7.5 - 10 - 50 - 60 FPS where applicable
[ADD] Auto creation of THM files saved into the PSP correct path folder
[ADD] Auto renaming rendered VOB into valid burning format VTS_nn_n.VOB
[ADD] FontSize+FontName+FontColor+LogoPosition support for WaterMark
[ADD] Correct renaming of all stream saved media
[ADD] Many other enhancement and bugfixes
v2006.build.19 (April 26, 2006)
[ADD] RightClick to select output folder destination
[ADD] Remembers the last source folder
[ADD] Join multiple similar files using DirectShow
[ADD] Import/Export profile to exchange or share profiles between users
[ADD] Play Internet Streams: mms:// http:// rtsp://
[ADD] Save Internet Streams: mms:// http:// rtsp://
[ADD] Encode and Play Playlists like: asx, m3u, pls, wmx
[ADD] AC3 5.1 channel support
[ADD] OGG encoding rewritten to support DirectShow
[ADD] FLV output format in addition to SWF
[ADD] Animated GIF output format
[ADD] MPC MusePack Audio output format
[ADD] JPG snapshot at defined position
[ADD] DVD- encoding using Mencoder (faster)
[ADD] DVD- Language selection (Audio Track) when encoding/playing
[ADD] TurnLeft|Right|180 when encoding using DirectShow
[ADD] Adjust volume when encoding
[ADD] Encode for a preset number of seconds
[ADD] Several features to the player
[ADD] Skin selection
[ADD] Many other features and bugfixes
v2006.build.17 (Jan 24, 2006)
[ADD] A New set of options In DirectShow mode
[ADD] Support to play and convert HDTV .TS files
[ADD] Support to play and convert VCD .DAT files
[ADD] Support to play and convert Matroska .MKV files
[ADD] WAV Audio codec to mencoder
[FIX] A bug disabling SUPER © from running on some PC units
[FIX] A bug causing error when encoding RealMedia or VIVO files
[FIX] A bug causing ‘Invalid’ error with some files larger than 4.9Gb
[FIX] An error in renaming PSP[H264] files to MAQxxxxx instead of M4Vxxxxx
v2006.build.13 (Jan 1st, 2006)
[ADD] iPod profile with both MPEG-4 & H.264/AVC support
[ADD] PSP profile with both MPEG-4 & H.264/AVC support
[ADD] Advanced H.264/AVC level/profile selection
[ADD] Optional 3GPP file wrapping release 5
[ADD] DirectShow input file support
[ADD] Xvid video to Sony Ericsson 3gp/3g2 profiles
[ADD] AAC audio to Nokia/NEC/Siemens 3gp profile
[ADD] AMR_wb audio to Nokia/NEC/Siemens 3gp profile
[ADD] AMR_wb audio to MP4 container
[ADD] AMR_wb audio to amr profile
[ADD] AMR_nb audio to MP4, MOV containers
[ADD] A-Law, WAV16 audio to MOV container
[ADD] WAV 8&16 audio to AVI container
[ADD] WAV 8&16 audio to the newly implemented WAV profile
[ADD] huffYUV video to AVI container
[ADD] MS-mpeg4-v1 video to asf, avi, wmv containers
[ADD] MS-mpeg4-v2 video to the wmv container
[ADD] MPEG-I video + mp2 audio to the vob(DVD) profile
[ADD] New VCD & SVCD profiles fully compatible with NERO CD burning
[ADD] VCD & SVCD, no more video/audio disabling to maintain full compatibility
[ADD] vob(DVD), no more video disabling to maintain full compatibility
[ADD] Aspect 16/9 to Nokia/NEC/Siemens 3gp profile
[ADD] FPS 11.988 / 14.985 to all 3gp, MP4, MOV containers
[ADD] A whole range of VideoScaleSize + Synchronisation with FPS
[ADD] PROMPT for MOV.3gp for H263+amr_nb files to play on QT
[ADD] PROMPT for MP4.3gp when H263+amr_nb files to play on QT
[ADD] File Crop and Pad options
[ADD] SUPER © minimizing button
[ADD] Some other tricks that we forgot to mention
[FIX] Most errors when coding with H.264/AVC
[FIX] sorenson video rendering in AVI, MOV containers
[FIX] Modifying the job list to select/unselect active files
[FIX] File wrapping for MP4, MOV containers
[FIX] File analyzing engine for better container/codecs identification
[FIX] All output extensions to CAPITAL
[FIX] illegal 23.976/30 fps on MPEG-II(vob)
[FIX] illegal film-definition on SVCD & DVD-AUTO
[FIX] illegal AMR Audio bitrates
[FIX] SUPER © can now Play 3gp files with amr_nb or amr_wb audio codecs
[FIX] vob(DVD) rendered files are fully compatible with TMPGEnc DVD Author burning
[FIX] Installion of SUPER © on 800x600 video screens is now possible
v1.811 (October 1st, 2005)
[FIX] At last… The bug that was terminating
the encode process before reaching the 20000th
video frame, was captured and exterminated.
You can now encode full length videos into your
favorite format…
Thanks to hundreds of you who helped to test
and find this annoying bug.
v1.809 (September 14, 2005)
[ADD] Now you may EXTRACT the AUDIO part of your
video files *.wmv, *.asf, *.rm, *.rmvb, *.viv,
*.ogg(video) into mp2, mp3, amr, aac, ac3 etc…
v1.808 (September 13, 2005)
[ADD] We have implemented a simple workaround
solution allowing direct encoding of video format
*.wmv, *.asf, *.rm, *.rmvb, *.viv, *.ogg files
into 3gp, 3g2 or swf (FLASH) etc…
This provides a greater flexibility with a highly
rendered quality without having to use any AviSynth
script. However, experienced users seeking for
speed, may continue to use AviSynth scripts that
are fully supported by SUPER ©
[ADD] Adding a progress bar to simply indicate that
the encoding process is still ongoing…
[FIX] Enhancing the handling of error
generation/reporting during encoding.
[FIX] The ‘Analyze Source File’ function is now
launched by a double-click on the selected file
(instead of 1 click). But, as long as the
‘Multimedia Analysis Box’ remains open, other files
may be analysed with 1 simple click.
v1.806 (September 10, 2005)
[ADD] Implementation of a multimedia file analysing
engine (Portions by MediaInfo) to show tags of ALL
source files.
[FIX] Minor tweaking.
v1.802 (August 1st, 2005)
[FIX] Modifying the MP4 files header when
mpeg4, DivX or xvid codecs are used inside
MP4 container.
[FIX] Fixing Aspect ratio to 6:4 (instead of 4:3)
when video Scale Size of MPEG I/II is on 352x240.
[FIX] Fixing Aspect ration to 11:9 (initially 16:9)
when video Scale Size of h263 codec is on 176x144.
[FIX] Removing not allowed frame-per-second when
selecting mpeg1video & mpeg2video codecs.
v1.800 (July 25, 2005)
[ADD] Modifying, adding some more hints to the
video Size scale & Aspect.
[ADD] Show/hide hints/tips is added with the
right click mouse.
[ADD] Show/hide the credit screen has been added
through the right click mouse.
[ADD] Keep on-top-of-all can now be
activated/desactivated (right click mouse).
[ADD] Check for update & a web page link are
added (right click mouse).
[ADD] Auto notification when a new version is
released (requires internet connection).
[FIX] The video Scale Size and Aspect ratio
are now synchronised.
[FIX] Fixing a bug when trying to remove a file
from the encode job list.
[FIX] Removing most not allowed Audio Bitrates
based on selected encoder and sampling rates.
[FIX] All parameters are saved when closing the
application. They are re-loaded at start-up.
[FIX] H.264 encoding is now 10% to 15% faster
than veriosn 1.799.
v1.799 (July 21, 2005)
Final & Stable
